01-16-2019
13:23
13:05
01-16-2019
13:23
13:05
I put my fit bit on the charger. He has been showing white lines since then. I have already tried to restart, but this has no effect.
02-20-2020 01:51
02-20-2020 01:51
Best Answer02-20-2020 03:08
02-20-2020 03:08
Hi, my wife is having the same issues with her charge3, plugged it in to charge last night and now it has white lines, I only bought in Dec for her Birthday, could you please let me know what I need to do, I have tried the long reset however they are still there. many thanks
Best Answer02-20-2020 03:25
02-20-2020 03:25
Best Answer02-20-2020 03:58
02-20-2020 03:58
02-20-2020 04:10
02-20-2020 04:10
Unfortunately, I got mine a year ago Christmas so it was just out of warranty. No replacement—just a 25% discount on their website, which I have seen them on sale for less. Seems like this model has a short shelf life with all the people having this same issue. I had years of use on all my other Fitbit devices. I will try buying one on eBay or move to another brand. Not happy.
02-20-2020 04:16
02-20-2020 04:16
Contact Customer Service. Unfortunately, I got mine a year ago Christmas so it was just out of warranty. No replacement—just a 25% discount on their website, which I have seen them on sale for less. Seems like this model has a short shelf life with all the people having this same issue. I had years of use on all my other Fitbit devices. I will try buying one on eBay or move to another brand. Not happy.
02-24-2020 08:50
02-24-2020 08:50
My fitbit is doing this as well. Plugged it in this morning, white lines now. What caused it and how do I fix it. This device is far too expensive and I have had it less than a year.
Best Answer02-24-2020 19:49
02-24-2020 19:49
02-25-2020 05:31
02-25-2020 05:31
Best Answer02-27-2020 12:58
02-27-2020 12:58
Best Answer02-27-2020 13:26
02-27-2020 13:26
MIne started today. I called customer support and they offered me a discount too since it was a year ago that I purchased it. The thing I brought to the customer support agent is if the product continues to have this issue why they don't fix it? There are 49 comments on this board spanning over a year all claiming the same issue. Fitbit needs to step it up.
Best Answer03-05-2020 19:29
03-05-2020 19:29
It seems that Fitbit will only stand by their products for one year. After that, if the screen fails, you have to buy another one. I guess that you get what you pay for over and over and over.
I am not going to buy another one of these products, as expensive as they are they should last longer than a year or two.
Best Answer03-06-2020 08:38
03-06-2020 08:38
Best Answer03-06-2020 10:06
03-06-2020 10:06
I’ve had the same problem but my lines are black. Mine also started when the tracker was under 10%! 2 black horizontal lines appeared, then daily more lines, then vertical lines started too. Now I can’t read the screen at all. I’m still wearing it because it still tracking everything, but I can’t read anything on it!
Best Answer03-07-2020 09:26
03-07-2020 09:26
03-07-2020 09:26
25% of what from what site? Sorry don’t understand lol
Best Answer03-07-2020 09:32
03-07-2020 09:32
Best Answer03-26-2020 19:36
03-26-2020 19:36
Mine looks just like that too.
Best Answer03-26-2020 19:58
03-26-2020 19:58
I've had the same issue and would very much like some support on this. I started to get a few horizontal lines on the charge 3 and now i have partial screen blankness nad more lines. I've tried both soft and hard resets to no avail. any help would be appreciated.
Best Answer03-26-2020 21:01
03-26-2020 21:01
I’ve tried everything suggest led still nothing
