02-06-2017
07:17
10:13
02-06-2017
07:17
10:13
Fitbit charge 2 is a new band. My daughter and I upgraded to charge 2. Bought them in December. We're in Jamaica for a week February, doing nothing but walking the beach. Mine was fine in the morning when I was done walking my 10000 steps my screen was cracked down the center and along the bottom. My daughter woke up the next morning and hers was also cracked the same way. We didn't do anything but walk the beach.
07-19-2017 21:12
07-19-2017 21:12
Mine also cracked this week and I did nothing. I have been overly protective of it. It will not charge now either. It just gets over heated and will not charge. I have been so in love with this and do not want to lose this. Any advise??
Best Answer07-20-2017 07:16
07-20-2017 07:16
07-20-2017 07:45 - edited 07-20-2017 07:56
found it 🙂 I'll try it out
Best Answer07-20-2017 07:57
07-20-2017 07:57
Best Answer07-20-2017 07:58
07-20-2017 07:58
Best Answer07-20-2017 08:18
07-20-2017 08:18
Thank you for your recommendation!! Claire helped me and the customer service was fantastic. I would recommend live chat to all. Thanks again!!
Best Answer07-20-2017 08:34
07-20-2017 08:34
07-20-2017 09:04
07-20-2017 09:04
Best Answer07-20-2017 09:52
07-20-2017 09:52
Best Answer07-20-2017 12:37
07-20-2017 12:37
Best Answer07-21-2017 10:18
07-21-2017 10:18
Best Answer07-21-2017 11:16
07-21-2017 11:16
I was coming in to check on this exact issue. I'm glad I am not the only one.
08:19
15:00
EdsonFitbit
08-04-2017
08:19
15:00
EdsonFitbit
OK This is certainly an issue with Fitbit quality and testing.
I purchased my Charge 2 on 25th June 2017 (John Lewis in the UK) and have just returned the product today 4th August and obtained a full refund. (Thanks John Lewis great service from you guys.)
The screen had a vertical crack from top to bottom. The crack occurred while on holiday in Spain where
temperatures where hot (42C - 107F) on some occasions. Just 6 weeks use and only 18 days of sunshine. No bangs or drops or jarring. The product should be able to handle this.
I had similar heat issues with 2 previous Charge HRs both of which developed the peeling rubber strap problem which typifies that product. The rubber around the screen starts to come away from the display.
The Charge HR does not like sweaty wrists or sunblock cream!
This is a great shame because I was really impressed with the functionality of the Charge 2 as it did everything that I needed.
I won't be buyng another Fitbit product until I see some assurance about improvements in quality and testing.
Simon
Moderator edit: format
Best Answer08-04-2017 09:27
08-04-2017 09:27
Received my replacement Charge 2 about a week and a half ago. It looks the same as my original. I guess we'll have to see if improvements have been made to the materials/constuction. In this Arizona heat it will be a good test. I'll report back in a month or so.
Best Answer08-05-2017 11:28
08-05-2017 11:28
Hi! Same thing happened to my Fitbit Charge 2, I've been wearing it with the heat and just realize there's a crack on it. Is this a normal thing that happens? Should I not be wearing it in the heat ?
Best Answer08-05-2017 11:32
08-05-2017 11:32
Best Answer08-06-2017 00:46
08-06-2017 00:46
Best Answer08-09-2017 00:43
08-09-2017 00:43
Based on all the posts regarding cracked screens it seems to me that you have a product defect. My screen also cracked today.
08-09-2017 09:49
08-09-2017 09:49
I had a similar problem where my Charge2 cracked right down the middle after 6 months of use. It was a a vertical snap in the plastic screen. I contacted Fitbit's Support via chat and after a few questions and sending screenshots of the front and back of the product along with an assigned case #, I was offered a free replacement or 50% off any new Fitbit model.
Best Answer08-09-2017 20:02
08-09-2017 20:02
