10-22-2018
11:56
15:03
10-22-2018
11:56
15:03
I got my charge 3 a week ago and at some point today the screen stopped lighting up when I turn my wrist. I haven't changed any settings and I'm turning my wrist in the exact same way as I was before so I'm not sure what the problem is.
08-03-2020 12:34
08-03-2020 12:34
Download the app to your phone log in Join via Bluetooth pair them via blue tooth.
08-22-2020 09:39
08-22-2020 09:39
This has become an issue again after firmware release 1.88.11. The new ‘don’t disturb’ option doesn’t allow to manage the Charge 3 to wake up when turning your wrist?
08-22-2020 14:03
08-22-2020 14:03
My Fitbit charge 4 is still working but it doesn’t light up
08-23-2020 01:21
08-23-2020 01:21
Solved with the help of another Fitbit user. When opening the menu holding the button, you have to scroll down to enable the feature ‘Rise to wake’. The menu will open DND and Sleep, but By scrolling down you can manage waking up the screen.
08-23-2020 05:17
08-23-2020 05:17
Thank you, I have spent hours trying to figure this out. I was ready to buy an Apple Watch but you helped me and now it’s working!
11-23-2020 17:27
11-23-2020 17:27
Mine some how turned off... how do I get it to turn back on?
01-14-2021 02:31
01-14-2021 02:31
Hi..on my Fitbit charge 3.. the screen is always dim... what can I do..?
I've tried pressing the sides for few seconds..
Thanks Jan
03-06-2021 10:19
03-06-2021 10:19
Working...finally after some frustration. Thanks.
03-25-2021 12:23
03-25-2021 12:23
Hi Jannypops, if you swipe right to left on your normal screen several times it'll go to a "Settings" option, in there is a brightness option; it's probably set to dim. Mine did that yesterday for some reason. You've probably worked this out by now, but it may help someone else. Wish they'd put all the settings type stuff in the same place!
04-13-2021 23:21
04-13-2021 23:21
Make sure your FitBit isn’t in sleep mode.
Go to Settings > Sleep Mode > Sleep Mode Off
09-01-2022 21:08
09-01-2022 21:08
Thank you so much. I did a software update and then this happened to me. Your solution worked! So happy!
09-06-2022 12:15
09-06-2022 12:15
thank you , it works for me 👌🏽
09-06-2022 21:50
09-06-2022 21:50
Open your Fitbit's Quick Settings, tap the screen wake icon (which looks like a watch) and change your Fitbit's screen wake option to Automatic, so every time you lift your wrist to look at your Fitbit, it automatically turns on.
Hope this helps
09-07-2022 07:10
09-07-2022 07:10
This finally worked! I had given up! Thanks so much!
09-07-2022 08:08
09-07-2022 08:08
12-12-2022 01:34
12-12-2022 01:34
In the quick settings screen, tap the screen wake icon to adjust the setting. When you set Screen Wake to Auto (Motion), the screen turns on each time you turn your wrist. When you set Screen Wake to Manual (Button), press the button to turn on the screen.
Regards,
Will
