10-14-2018
17:31
15:06
10-14-2018
17:31
15:06
After downloading the new firmware for the Charge 3 my screen no longer wakes when rotating my wrist. I either have to double tap the screen or press the side button to wake the screen. Holding the side button in no longer takes me to a menu either. The device just vibrates 3 times when the side button is held. I restarted the device and continue to have the issues.
Any recommendations?
02-12-2019 15:49
02-12-2019 15:49
Best Answer07-10-2019 19:46
07-10-2019 19:46
I couldn’t do it. I’m still frustrated and it’s not working the screen wake won’t wake up and I’m just hopeless
Best Answer07-21-2019 19:37
07-21-2019 19:37
I had the same issue. What I did is simple. After going through messages in this chat forum.i long pressed the side button downward once. It opened the screen wake settings screen.it was in disabled mode. When I tapped on it, the screen wake is set to ON..there you go..
07-25-2019 05:23
07-25-2019 05:23
YES, wake turned on, but it doesn’t wake, any answers for that?
08-12-2019 23:38
08-12-2019 23:38
Thank you!!
Best Answer08-31-2019 12:02
08-31-2019 12:02
Thanks for the edit update. It worked fine after I followed your directions!
Best Answer08-31-2019 12:26
08-31-2019 12:26
09-22-2019 13:18
09-22-2019 13:18
Thank you koolforkatz! It's working again
06-20-2020 19:03
06-20-2020 19:03
Thank you ,your instructions solved my problem easily
Best Answer06-21-2020 05:35
06-21-2020 05:35
Glad to know it worked for you.good that I posted when it resolved for me..
Best Answer07-31-2020 10:48
07-31-2020 10:48
This is not the answer.
koolforkatz provided the actual answer.
Best Answer08-20-2020 10:37
08-20-2020 10:37
Thank you for this!!! I was just having the same issue!
Best Answer09-06-2020 10:41 - edited 09-06-2020 10:43
ANy ideas if it doesn't allow you to change status to active "awake" setting? Grayed area won't change after tapping.
09-06-2020 16:14
09-06-2020 16:14
I've never had that issue.
Have you tried a full reboot of the watch through its settings menu?
Best Answer11-13-2020 17:52
11-13-2020 17:52
Did not work for my Charge 3
06:42
04:54
WilsonFitbit
03-16-2021
06:42
04:54
WilsonFitbit
Me too, grayed out and doesn't let me change. I don't have a reboot on watch menu. Sure seems like every time there's an upgrade of software it causes a bunch of trouble! Love my charge 3, but tired of always having to reset things, just want it to continue working as is.
I get to the wake screen and it's grayed and doesn't let me change it? Any ideas?
Moderator Edit: Merged posts
Best Answer03-18-2021 05:00
03-18-2021 05:00
Hello everyone! @PGST, welcome to the community forums!
If the Screen Wake setting is grayed out, it is possible that Sleep Mode on your Charge 3 is On. Take into consideration when this is On, turning your wrist won't cause the tracker's screen to turn on.
For this, press and hold the button and swipe left on Charge 3 for a faster way to access certain settings. Tap a setting to turn it on or off. When you turn off the setting, the icon appears dim with a line through it. Then you can also adjust the Screen Wake option in the quick settings.
On a side note, I believe you're familiar with the steps for a restart but you can also find the instructions here.
Hope this helps!
03-18-2021 07:58
03-18-2021 07:58
Thank you, I stumbled upon this, tapped the "sleep" button and found the "Wake" functioning. Also found the "dim" setting to correct that. After a couple of weeks, I have my Charge 3 working again. I had tried the reboot because my screen was so dim I couldn't even see it. After the reboot, everything went wrong and nothing was fixed. But now I'm good. Thanks
03-20-2021 06:07
03-20-2021 06:07
@PGST, I'm glad to know that now everything is good and thanks for the information!
Hope you can continue tracking towards your fitness goals!
Have a wonderful day!
Best Answer04-15-2021 08:02
04-15-2021 08:02
Ehen I put charging cable on I cannot hold button down. Is there another way to reboot?
