10-17-2017
20:11
09:26
10-17-2017
20:11
09:26
Without knowing what would happen upon setting an 8th alarm in my fitbit, i innocently added a 7:15 am possible alarm. Turns out when you have 8 and go to “set an alarm” in the app, it will pop up a window saying that you can only have 8 and must delete one. I simply wanted to set one I already had chosen, and found that there is no way to do this in the app, and also no way to remove an alarm in the app. I logged in a computer, went to the little gear in the right hand corner, and deleted some alarms. I also tried to set one I already had chosen and then synced my fitbit through the app to get it to take. Several app restarts, page reloads, and syncs later and I get the same message about 8 alarms in the app, even though the dashboard version shows 5. It also takes more than a simple sync to get an alarm to set from the computer. I generally have to sync and restart the app several times to get it to work. This seems like a simple fix to a frustrating issue, yet I have seen a few other posts about it.
10-17-2017 23:37 - edited 10-17-2017 23:39
@Zbakk, if you simply want to turn on an alarm you previously set, through the app, find tyr alarm and turn it on.
Or, onthe Charge 2 tap through the alrms, find the correct alarm, hold the button in. This will turn it on.
Your not going to be able to create an alarm that was previously created.
Best Answer10-17-2017 23:37 - edited 10-17-2017 23:39
Best Answer12-04-2017 07:25
12-04-2017 07:25
I am having the same issue. I want to delete some alarms and I can't get into it to do so because I have set 8. The app and the computer won't let me delete any.. Any suggestions?
12-13-2017 12:04
12-13-2017 12:04
Go to the list of your current alarms.
Hold finger on alarm.
Choose edit or delete.
Best Answer12-13-2017 14:41
12-13-2017 14:41
Best Answer02-23-2018 14:46
02-23-2018 14:46
Nope, that didn't work, cannot get past error message.
Best Answer02-23-2018 14:52
02-23-2018 14:52
Which of the 4 different devices is the app on? Have you tried through the web site?
Best Answer02-24-2018 14:06
02-24-2018 14:06
My device is the Charge 2, less than 6 months old. Accessed the alarms through the website dashboard on my laptop and deleted 2 alarms, but still have the message on my phone.
Is there a method of bypassing the message on the phone?
Best Answer02-24-2018 14:36
02-24-2018 14:36
Best Answer02-07-2019 08:27
02-07-2019 08:27
I had to phone Fitbit and have them go into my account and delete them.
