12-07-2018
10:23
14:34
12-07-2018
10:23
14:34
How do I set the alarms on the charge 3?
12-11-2021 08:20
12-11-2021 08:20
12-11-2021 13:49
12-11-2021 13:49
12-11-2021 15:40
12-11-2021 15:40
12-12-2021 23:03
12-12-2021 23:03
My device does not have this silent alarm menu. I can't figure out how to change my alarm now me screen is broke. I've looked all over for the + icon too.
12-13-2021 07:49
12-13-2021 07:49
07-22-2022 19:07
07-22-2022 19:07
What screen is the app "dashboard". A screenshot would be most helpful and understand there might be a difference between iOS and Android and those with a premium plan and those without. The only thing I see when I push a "+" icon is "Add Sleep Log". When I'm in my profile window the only "+" is for adding a device.
Sorry - from what you've given, no help at all.
07-23-2022 08:07
07-23-2022 08:07
07-23-2022 08:55 - edited 07-23-2022 09:18
RecoveryRunner, you are correct and your solution worked great. My post, which landed under your post - so it seemed pointed to you - was inspired by my angst after reading the first post (page 1) of this series where there was talk of a dashboard and plus sign.
I apologize for not noticing the chronology of the posts and not starting my reading on the last page. As your post resolved the issue perfectly (I now know how to set and delete alarms) one generation would say, “Your king fu is strongest.” Another would say, “You are king of the lab.” Of course, these days, so as not to make an assumption, I should probably spell it “kingx”.
Thank you again for your very workable solution.
07-23-2022 09:09
07-23-2022 09:09
