12-07-2018
10:23
14:34
12-07-2018
10:23
14:34
How do I set the alarms on the charge 3?
05-03-2019 17:26
05-03-2019 17:26
I found no such + sign in the lower lefthand corner of the dashboard. Only a Fitbit icon. There is a plus sign next to the big black O. It's on top of the battery.
06-25-2019 20:02
06-25-2019 20:02
Now how do you do it with the new app update? I don’t see the feature anymore!
07-02-2019 10:45
07-02-2019 10:45
I would like to know that too.
With the new update I can not find how to set the alarm
07-02-2019 12:40
07-02-2019 12:40
You should see a + sign on the lower right corner of the dashboard. If you click on it, you will find the way to set the alarm.
07-02-2019 13:20 - last edited on 02-14-2020 16:29 by LiliyaFitbit
Thank you but I don’t see it.
07-02-2019 13:43
07-02-2019 13:43
07-02-2019
14:16
09:42
JuanJoFitbit
07-02-2019
14:16
09:42
JuanJoFitbit
I think you didn’t receive my picture
🙈 I can not find it.
I think you mean the app and not the dashboard you can enter on the internet.
Because on the dashboard on internet I finally found it there but I miss it in the app.
Found it.
In the app you need to click on your profile picture in the upper left corner
then chose your charger and then you can change your alarm
07-02-2019 21:16
07-02-2019 21:16
I updated the app to the new look, and I cant find the + button to change my alarms. Help!
07-03-2019 04:01
07-03-2019 04:01
07-13-2019 20:47
07-13-2019 20:47
There are 5 + signs on the new app. Which one do I tap?
07-13-2019 21:58
07-13-2019 21:58
07-14-2019 04:11
07-14-2019 04:11
07-14-2019 14:36 - edited 08-25-2020 06:13
Update: From clock firmware version 28.20001.88.11 and on it is no longer possible to set the alarm from the mobile app. You can set it via the clock screen instead.
In my android version of the software the dashboard look like the picture below. When I drag the screen downwards to synchronize, the battery charge icon appear high up to the left. This area is actually possible to press and is a shortcut to the unit's settings overview page. (In my case a Charge 3). On that page you do find the "Silent Alarm" header which in its turn is possible to click to enter alarm settings...
07-14-2019 16:46
07-14-2019 16:46
07-16-2019 02:53
07-16-2019 02:53
I just bought my Fitbit charge 3. I used my alarm in my 2. I do not have the icon in the right corner, and I can not figure out how to get into the account settings.
thank you in advanced
07-16-2019 07:27
07-16-2019 07:27
07-16-2019 10:54
07-16-2019 10:54
07-16-2019 11:37
07-16-2019 11:37
@Clubmeder wrote:
Go to Fitbit app. Find the charge 3 picture with battery charge amount
under yours by dragging down. Tap the charge 3 picture and a new screen
will open with silent alarm about 2/3 way down.
Hope this helps.
some people shouldn't have nice things lol
07-16-2019
14:15
06:16
JuanJoFitbit
07-16-2019
14:15
06:16
JuanJoFitbit
Thanks Janice. I'm on the new app that doesn't gav a turquoise circle on
the dashboard.
Appreciate the input though.
Sorry xm. Dont know where that last line came from!!!
Wasn't from me!
Moderator edit: merged reply
07-19-2019 11:57
07-19-2019 11:57
I do not see a set alarm icon in my Fitbit app. ?.?????
