12-07-2018
10:23
14:34
12-07-2018
10:23
14:34
How do I set the alarms on the charge 3?
08-30-2019 09:28
08-30-2019 09:28
08-30-2019 10:17
08-30-2019 10:17
08-30-2019 10:51
08-30-2019 10:51
Solved. Its moved under the profile
08-30-2019 14:09
08-30-2019 14:09
08-30-2019 16:24
08-30-2019 16:24
It doesn't help when we purchase an expensive device only to have it fail between the app and the device, when the device RELIES on the app. And for their support to have numerous, countless reports of the same issue, and nothing to be done.
It has NOTHING to do with someone not spending their time setting the **ahem** thing up, it just fails.. and yes it is connected to bluetooth fine, or was. it depends on if it wants to or not.
Nothing to do with the user, it's the device. Read the google play comments, apparently since the last update everyone is having sync issues. Not only that, if I set an alarm, it takes upwards of 20 minutes for the charge 3 to recognise it, let alone setting things like Celsius from Fahrenheit.
So, sure, it doesn't help calling people wankers, they've already got the money, yeah? nah.
08-30-2019 20:56
08-30-2019 20:56
10-16-2019 20:59
10-16-2019 20:59
Thank you for the pictures, found it.😀
10-17-2019 06:39
10-17-2019 06:39
12-01-2019 22:58
12-01-2019 22:58
Thank you @GridRunner . On the android ap it is buried very deep, and there is no way to customize the home screen or make it more easily accessible. Seems like an over site by the developers. Maybe now that Google bough them, things will be better designed for Android.
12-18-2019 20:47
12-18-2019 20:47
Hello,
I am having difficulty following the alarm set up instructions. On my dashboard in the app (which I just downloaded) - I can not see a + sign icon. Can you help?
12-18-2019
20:54
12:03
JuanJoFitbit
12-18-2019
20:54
12:03
JuanJoFitbit
Thanks. You are the only one who has been able to explain it to me. None of the other suggestions appear on my app.
Not on my app - and I just downloaded the latest version for IOS
Moderator edit: merged reply
12-19-2019 12:50
12-19-2019 12:50
12-19-2019 13:55
12-19-2019 13:55
Such a convoluted process, when it should be a part of the device itself.
You forgot the final step, too. Try for 10 minutes to sync with the device then wait an hour for the alarm to appear.
12-19-2019 14:06
12-19-2019 14:06
12-19-2019 14:31
12-19-2019 14:31
12-19-2019 14:47
12-19-2019 14:47
From home page go to top left, click on your picture - account page.
Account page - click on charge 3
Charge 3 page - scroll down past wrist placement. Mine says Silent Alarm, click then on top right click on + to set alarm.
12-19-2019 14:54
12-19-2019 14:54
12-19-2019 16:04
12-19-2019 16:04
12-19-2019 18:17
12-19-2019 18:17
12-19-2019 19:37
12-19-2019 19:37
