12-07-2018
10:23
14:34
12-07-2018
10:23
14:34
How do I set the alarms on the charge 3?
10-19-2020 14:53
10-19-2020 14:53
It would be useful if the answers included details of the device, os version and app version.
Device: iPhone 6
OS: iOS
App: 3.32.1 (999)
For this setup there is NO option for setting the alarm via the app.
Best Answer10-19-2020 15:19
10-19-2020 15:19
Best Answer10-20-2020 06:18
10-20-2020 06:18
I have an iPhone 7Plus, iOS 14.0.1. I have synched it to my FitBit. My screen does not have a circle with a plus to go to those options.
10-20-2020 06:41
10-20-2020 06:41
Best Answer10-20-2020 07:32
10-20-2020 07:32
10-20-2020 09:34
10-20-2020 09:34
Best Answer10-20-2020 12:57
10-20-2020 12:57
Oops.
iOS version 12.4.8
Best Answer10-21-2020 08:27
10-21-2020 08:27
Thank you. I finally figured it out that the alarm could only be set on my FitBit Charge 3. It took a couple of tries to get it to work. I just wish FitBit had better documentation. What they have is truly non-existent.
Thanks again!
10-21-2020 10:06
10-21-2020 10:06
Best Answer10-21-2020 18:50
10-21-2020 18:50
Best Answer12-28-2020 20:29
12-28-2020 20:29
Why the heck did the ability to set an alarm via the ios app get removed?! I can’t stand trying to set an alarm on this tiny little screen! Just a few months ago it worked fine from the app! Grrrrr Fitbit!
Best Answer12-29-2020 09:06
12-29-2020 09:06
Best Answer02-10-2021 14:46
02-10-2021 14:46
I haven’t used my Fitbit since last year.
I remember it was really easy to access alarms & sleep mode.
I have tried to follow your instructions, but sadly I am unable to see the + and any of the options on my app.
I have gone into every option & setting.
I seem to be missing something.
Please could someone help me?
I look forward to hearing from you at your earliest convenience.
Best Answer02-10-2021 16:52
02-10-2021 16:52
Best Answer05-03-2021 10:22
05-03-2021 10:22
I have found the alarm setting on my Fitbit, but I can only set the hour - there does not appear to be a way to set the minutes. Am I missing something?
05-03-2021 10:46
05-03-2021 10:46
Hello everyone. Thanks for participating in the community forums.
@jmiles Make sure that you're following the correct instructions to set alarms on your Charge 3. For more information, I recommend visiting the following link: How do I manage alarms on my Fitbit device?
You can also check the Charge 3 manual here.
Hope this helps.
Best Answer05-03-2021 10:59
05-03-2021 10:59
Thanks for your quick response. However, I still can't find any description that helps. When I follow the instructions for setting an alarm on my Fitbit, I can get as far as selecting the hour I want, and am or pm, but there doesn't seem to be any way to adjust the minutes.
The User Manual simply directs you to the website help, and doesn't actually contain any instructions.
Best Answer05-03-2021 14:00
05-03-2021 14:00
05-03-2021 16:04 - edited 05-03-2021 20:57
Think I got it. Thanks!
05-04-2021 07:34
05-04-2021 07:34
following this discussion to try and create a new, recurring alarm on my device. device does not offer option to choose days of the week.
