07-09-2021 06:20
07-09-2021 06:20
A few days ago I accidentally showered in my HR it was like a minute had passed when I realized it. I took it off, but it had gone blank. I have allowed it to dry out but it’s still not charging. Is it completely gone at this point?
07-09-2021 07:33
07-09-2021 07:33
Hi @Draza77 usually people put the devices in a bowl of dry rice for about two days, after which all the contact points are cleaned and the device restarted and charged. Sometimes charging the unit fries the battery or something inside, from what I've seen posted on the forums. It might just need more time to get any residual moisture out. Some people have use hair dryers, too. You might want to give it more time, but you might want to check into which Fitbit you'd like to try next.
Best Answer07-09-2021 09:18
07-09-2021 09:18
