01-18-2019
23:18
17:54
01-18-2019
23:18
17:54
I've been using my Charge 2 silent alarm to wake up every morning, but there are some mornings that my watch doesn't react. I occasionally will have to reset it and then it works, but I was wondering if there was some secret setting I was unaware of that allows you to snooze the alarm simply by raising your arm.
01-19-2019 06:38
01-19-2019 06:38
Hey @Nylla, it is great to see new faces around! When you say that there are some mornings that your watch doesn't react, are you saying that it won't vibrates when it should? If that is the case, and after several restarts the issue persists, I suggest you to delete all the alarms you have set (through your Fitbit account) and then re add them. Don't forget to sync your Charge 2 after that.
Let me know how it goes!
