02-10-2016
17:58
20:15
02-10-2016
17:58
20:15
02-10-2016 22:11
02-10-2016 22:11
This happened to me when the charge was very low and a call came it wouldn't stop vibrating. I have it on charge but no sign of life yet 😞
Best Answer02-10-2016 22:39
02-10-2016 22:39
Best Answer03-15-2016 03:38
03-15-2016 03:38
Best Answer10-10-2016 04:55
10-10-2016 04:55
OK, so this morning my alarm went off at 7:30 am and continuously buzzed for about 20 minutes until I read this post. Plugged it in, held it until it stopped buzzing, but now the dang thing is dead. Trying to resurrect it now. This is disappointing - I have a medical condition where I need to set 12 alarms per day, and so far the fitbit has worked. I'm going to revert back to my other old-timey watch. Not a happy camper right now. Thanks for this post.
Best Answer10-15-2016 07:10
10-15-2016 07:10
Hello everyone and welcome to this thread @vividee Seems odd that your Fitbit tracers' silent alarm didn't stop vibrating. I would like to follow up and would like to know if the issue persists. If so, I noticed that you have restarted your devices and since this didn't work, my best advice is to contact our Customer Support team so they can investigate further and get this issue sorted out.
Keep me posted on the outcome my friends! ![]()
12-16-2016 05:22
12-16-2016 05:22
I had this happen for the first time this morning. Did anyone call customer service as recommended? What was the solution?
Best Answer12-16-2016 06:49
12-16-2016 06:49
Hey @SuziQ_1980, let me give you a warm welcome to the Community! By any chance, have you tried to restart your Charge HR? If you haven't, I suggest you to try that out. If after try that, the issue persists, you definitely have to contact Fitbit support, so they can take a look into your account, see what is going on with your tracker and choose the best option to get you back on track.
Catch ya' later!
Best Answer06-20-2019 05:56
06-20-2019 05:56
I had the same thing happen to me a couple of weeks ago! Plugging it in and holding the side button down seemed to work to reset it and it's been fine since then, apart from that the alarms now don't vibrate as well but make more of a noise...
