02-06-2019
12:13
17:54
02-06-2019
12:13
17:54
I’ve had a lot of trouble with the silent alarms lately. They haven’t been going off, reset it etc and will work again but later stop. It also was making its own alarms- however I’ve seemed to fix this issue. I now have the issue of the snooze not working. If you don’t dismiss the alarm, it usually will go off again in 9 minutes but it hasn’t been going off for the second time. What else can I do? I feel I’m always resetting it, deleting alarms to fix problems with them.
thank you
02-07-2019 10:38
02-07-2019 10:38
@Laurentherese It's great to see that you've visited the Fitbit Community! Sorry to hear that your alarms aren't working. It seems that you have tried most of the suggested troubleshoots and thank you for taking the time for this. I suggest you refresh the link between your phone and your tracker by going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. After this remove the tracker from your account (tap the tracker's icon then the trashcan icon) and set it up again. Setup the alarms and see how it behaves.
Let me know how it goes!
Best Answer02-07-2019 10:41
02-07-2019 10:41
Thank you
it conveniently worked this morning after I did a rest run at work yesterday at work and it didn’t work. I didn’t try anything else so not sure what’s going on haha
but I wil try your suggestion if it happens again 🙂
02-10-2019 08:33
02-10-2019 08:33
@Laurentherese thank you for the update. Happy to hear that your tracker is working now and hope it helps you achieve your daily goals.
I'll be around!
