Size does not fit small wrist
My FitBit is a gift from a son, which makes it awkward to return it. But it is tooo large for my wrist. The rectangle face plus the wristband connectors causes it to stick out on either side. Tightening the wrist band doesn't help. Additionally, it slides around hitting my wrist bone and leaving small bruises. Obviously I need something with a smaller face. But is there any way to solve the issue with this product?
2 REPLIES 2
Try wearing it higher up you arm away from your wrist.
Great idea, but I tried that and the wristband itself is not long enough. I am 85 years old and therefore have a lot of hanging skin, but none of it is on the wrist. Maybe I need to get a larger wristband. I’ll check it out and see thanks for your response.
Sent from my iPhone
