11-01-2018
04:11
15:03
11-01-2018
04:11
15:03
My charge 3 is not automatically tracking my sleep. The only way it will track is if I manually tell it that I am going to sleep and that I’m awake. I reset the Fitbit and tried it again last night but did not track again.
02-26-2019 07:11 - edited 02-26-2019 07:13
Thanks for stopping by @58Nana and @Baz2000! Sorry to hear that the sleep tracking is not working properly on your Charge 3 trackers.
While reading your posts I was wondering if the sleep data is missing on the Fitbit app or on the tracker itself?
If you're missing the sleep data on the Fitbit app, please make sure that your Charge 3 is syncing with the app. You can verify this by checking if you're also missing steps, floors, etc. If so, please follow the tips and recommendations provided at: Why won't my Fitbit device sync?
Also, make sure you've reviewed: What should I know about sleep stages?
Thanks for helping out my friend @KimD.! Glad to hear you sorted this out. ![]()
Hope this helps. Keep me posted!
Best Answer02-28-2019 11:09
02-28-2019 11:09
My Fitbit Charge 3 is not tracking sleep on the tracker itself. I have attempted all of the suggestions to resolve the issue to no avail. If I cannot resolVe it shortly I will be returning the device for a refund. Are you able to suggest a fix?
03-01-2019 03:34
03-01-2019 03:34
Maybe @MarreFitbit can offer some support
Best Answer03-01-2019 04:09
03-01-2019 04:09
Welcome on board @Keelawee! Thanks for attempting all the suggestions in the forums to solve this issue. Nice way to go!
While reading your post I was wondering if you've checked that your Charge 3 is syncing your sleep in your Fitbit dashboard? Can you please confirm if the sleep data is only missing in the tracker itself? Are you getting the "Sleep not tracked" message?
Thanks for ping me out @KimD.! ![]()
Looking forward to your reply!
Best Answer03-01-2019 11:39
03-01-2019 11:39
@MarreFitbit thanks for responding. Yes it is syncing to my app. Although Some days despite having my charge 3 set to auto sync all day I gave to force it. Which often takes hours ... having to go through rebooting phone, charge 3, turning Bluetooth on and off ... Eg Thursday mid morning it had not synced since Wednesday morning around 8am. It was not until late Thursday I managed to sync my steps etc.
Best Answer03-02-2019 08:31 - edited 03-02-2019 08:32
Thanks for letting me know your sleep is syncing to you app @Keelawee. However, I'm still wondering if the data is only missing in the tracker? I partially got your message, I'm still a bit confused since you mentioned syncing issues with other data too.
In regards to the syncing difficulty, sometimes I have to sync my tracker twice in the morning to see my sleep data. But it takes just a few seconds, so I'd recommend to take a look at: Why won't my Fitbit device sync?
Looking forward to your response!
Best Answer03-02-2019 15:51
03-02-2019 15:51
I am sorry but this is getting ridiculous ... It is obvious from my previous reply and your last response that it is not showing on my Fitbit Charge 3 ... When I manage to sync to the FitBit it does show there.
My issues with this device which is about 2 weeks old are two pronged.;
1. "Sleep not tracked" is what shows on the face of my FitBit Charge 3
2. Despite having it set to sync continually it does not, and it does not sync readily when I manual sync. I HAVE followed all the fixes suggested but to no avail.
It appears that I am not the only one having these issues and no one's seems to be getting satisfactory answers.
Could this please be escalated to your technicians? If it cannot be resolved within the next 24hrs I am returning the device for a refund and will be looking at alternate brands!
Best Answer03-04-2019 06:17
03-04-2019 06:17
Thanks for clarifying the issue @Keelawee. We’re aware of "Sleep not tracked" message on the tracker itself and are working to identify a resolution as quickly as possible.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Please let us know if there's anything we can do to assist you in the meantime.
Best Answer03-04-2019 11:10
03-04-2019 11:10
So i have been looking at purchasing a Charge 3 - primarily for tracking sleep - but based on the complaints here, i may wait until i know that the bug is fixed.
Best Answer03-04-2019 13:16
03-04-2019 13:16
No idea. But as it is a 'known' issue why isn't it being flagged as such ? Bloody frustrating when you buy something expecting it to do certain things and it doesn't. AND it isn't like it is a new issue from what I can tell ... It has been going on for quite a while. One return coming up, which I am sad about because the size and style is exactly what I wanted!
03-05-2019 11:46 - edited 03-05-2019 11:46
Hi there @GolfMomma and @Keelawee! I'd like to give thanks for the feedback you've provided towards our product.
If there any questions present, please let me know. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
Let me know if you have any questions.
Best Answer03-29-2019 05:52
03-29-2019 05:52
Hi, I had the same problem with the app not tracking my sleep nor my heart rate. I tried the tips the Fitbit moderator suggested to no avail too. It’s turns out that in my IPhone privacy settings: Bluetooth sharing had to be on for Fitbit and in the motion & fitness: Fitbit has to be enabled. Then go to the back to settings, look in the lists of apps down loaded for Fitbit & make sure Bluetooth is also enabled. This worked for me. I didn’t have them all enabled.
Best Answer04-01-2019 11:40
04-01-2019 11:40
Welcome to the Fitbit Community @Gcedil1! I'm very glad to hear your Charge 3 started tracking your heart rate and sleep stages again. Thanks so much for sharing the steps that worked for you, I'm sure they will be of help to other users. ![]()
Don't hesitate to let us know if you need further assistance. Have a nice day!
Best Answer04-01-2019 12:59
04-01-2019 12:59
04-02-2019 12:51 - edited 04-02-2019 12:53
Hello @Keelawee, thanks for coming back and for trying the suggestions posted by @Gcedil1.
The issue you're experiencing is totally different from what she posted. That's why I notified you that we’re aware of "Sleep not tracked" message on the tracker itself and are working to identify a resolution as quickly as possible.
I'll make sure to keep you posted when updates are available. Have a nice day!
Best Answer04-29-2019 14:38 - edited 04-29-2019 14:39
After the latest firmware update yesterday it did not track my full night's sleep. It never had this issue before the update. It probably didn't track at least 90 minutes of the first part of the night. I did get up after about 90 minutes of sleep to use the restroom and it was about 5 mins up. I'll see how it does tonight.
Best Answer04-30-2019 08:24 - edited 04-30-2019 08:25
Hello there @sanman202, thanks for jumping in here! This happened to my 3 days ago just after the firmware update.
However, I found out that the update had apparently shut off the 'on' heart rate setting on my device. After having reset it to 'on', the heart rate monitoring came on again. As you know, sleep stages are based on your heart rate data. So, open the Settings app and find Heart Rate. Make sure Heart Rate is On.
You can also take a look at this post to make sure you get your sleep stages next time. 😉
Keep us in the loop, we'll be around.
Best Answer07-11-2019 10:22
07-11-2019 10:22
I as well am having this issue. When I first purchased the Charge 3 fitbit it did it automatically. The last update that was done - I believe it took it away. Please bring it back.
Best Answer07-14-2019 03:45
07-14-2019 03:45
I updated My fitbit app and now it does not track automatically my sleep. I already restarted the devise, I already delete and reload the app. I don’t want to put manually when I am going to sleep and when I wake up. All the solutions presented in he forums don’t work.
08-24-2019 21:30
08-24-2019 21:30
I have an issue with sleep. I wake up every couple hours. I usually get 5-6 hours broken up. My fitbit app charge 3 is showing 9+ hours of sleep. I’m not even in pjs that long, let alone asleep.
I have never clicked sleep now. What is the issue? My fitbit is snug and about two inches above the wrist all the time, including sleep. Please advise. Thanks!
