11-01-2018
04:11
15:03
11-01-2018
04:11
15:03
My charge 3 is not automatically tracking my sleep. The only way it will track is if I manually tell it that I am going to sleep and that I’m awake. I reset the Fitbit and tried it again last night but did not track again.
11-19-2019 04:11
11-19-2019 04:11
How do you do this on the computer?
11-19-2019 04:12
11-19-2019 04:12
@KimD. How do you do it on the computer?
12-19-2019 17:25
12-19-2019 17:25
Hi I’ve just purchased charge 3 and I’m up and down at night when I go to sleep now it will track the first couple of hours then when I get up for a couple of hours then go back to bed I was wondering if it will keep tracking my sleep for that correct day and also my charge 3 watch says not tracking sleep when up, is this normal.
Many thanks
12-20-2019 01:00
12-20-2019 01:00
I have an iPhone 11 and iPad Pro (first generation) but with the iPad don’t seem to find the charge 3 under Bluetooth but when I get my sleep score on phone it will appear on iPad
12-20-2019 10:35
12-20-2019 10:35
I have the same issue with my sleep but it will track it when I first fall asleep but when I wake up it will stop then when I return to bed and sleep it will track it on the next day ? Weird....also when I’m asleep my bpm would rate about 109 is this ok
12-23-2019 02:32
12-23-2019 02:32
I track my logs on iPad and iPhone 11
12-24-2019 06:04
12-24-2019 06:04
Sorry for the late response I use an iPad and iPhone 11
01-24-2020 06:09
01-24-2020 06:09
I have owned a fitbit charge 3 for a few months now and it has never tracked my sleep where the fit bit 2 had no issues.
The fitbit screen says sleep not tracked, but everything is set properly. Seems to me the fitbit is the problem
01-24-2020 06:24
01-24-2020 06:24
Fitbit charge 3 tracks sleep automatically so when you wake do you open your Fitbit app and resync it also do you have all-day sync switched on
01-24-2020 06:34
01-24-2020 06:34
Where do I check for all day sync?
01-24-2020 06:47
01-24-2020 06:47
01-24-2020 06:54
01-24-2020 06:54
Okay thanks, it's on
01-24-2020 10:40
01-24-2020 10:40
02-17-2020 08:16
02-17-2020 08:16
Thanks to Davey137 and others in these forums. My Charge 3 and iOS app did not give me a sleep score for the first week. I made the following changes and now I've had a sleep score consistently for the past week. Here is what I did:
1. Clear all prior data/links - I erased the Fitbit program on my desktop computer, erased the bluetooth connection from my iPhone to the Fitbit, cleared data and restarted the Fitbit using the Settings menu (Settings -> About -> Clear User Data & Reboot).
2. iPhone to Fitbit - set up a bluetooth connection to Fitbit
3. iPhone Fitbit App Settings - (i) Turn off "All-day sync" (the sync will occur when you turn on the Fitbit app); (ii) Set your Target sleep schedule (i.e., 9pm-6am).
4. Sleep Score - When I wake up, I open the app and the iPhone and Fitbit sync, download info to the app, and analyze/calculate a sleep score. I did notice that the 1st time I turn on the app each day, it has a hard time sync'ing, but if I wait a few minutes, the sync will occur the 2nd/3rd times I open the app.
Note: When going to sleep, DO NOT turn on the "Begin Sleep Now" feature in the app. Seems counterintuitive, but I read it in these forums and it worked. Now I just go to sleep, and now everything works fine.
03-30-2020 23:30
03-30-2020 23:30
Why is it that clicking “start sleep now” in app doesn’t track sleep cycles, but letting the Fitbit track of automatically does? Mine doesn’t seem to track if properly on its own, saying I only slept 1.5 hours when I had 6 or more.
I would like to start and end sleep through the app so I know the hours are accurate but still get the detailed data of REM, light and deep sleep. Why is that not possible?
03-30-2020 23:46
03-30-2020 23:46
It worked perfectly in charge 2, but never for charge 3, I regret upgrading actually feels like a downgrade or broken product.
