10-08-2016
07:53
20:15
10-08-2016
07:53
20:15
10-08-2016 09:39
10-08-2016 09:39
Fab
Though Fitbit recommends not to shower or swim with the trackers.
The Flex 2 is swim proof
The Alta is shower proof (not swim proof)
All other trackers aren't shower proof or swim proof.. when wearing while showering and it gets damaged, it can void the warranty.
Can I swim or shower with my tracker?
All Fitbit trackers are water-resistant, which means they are rain-proof and splash-proof and can stand up to even the sweatiest workout. Do not swim or shower with your tracker unless noted below:
Whenever you get your tracker wet, dry it thoroughly before putting it back on.
10-08-2016 10:46
10-08-2016 10:46
I'd ignore the recommendations. As long as you are careful and don’t submerge your HR, you’ll be fine. Just be sure to dry it off all the way, inside and out when you get out of the shower. I've been very happy with the results. I'm sure FitBit would like you to upgrade, but no I see no need.:)
Best Answer10-09-2016 12:31
10-09-2016 12:31
You can feel free to ignore the recommendations, but to put it bluntly, just don't be surprised when Fitbit ignores your requests for service or warranty if you should ever encounter problems.
I know that when I set up my Surge, the Surge 101 page suggested a couple of soap-free cleansers and they're also listed on the product care page:
"To remove build-up of lotions and oils (such as sunscreen, insect repellent and moisturizers) that can be trapped beneath the band, we recommend that you use a soap-free cleanser like Cetaphil Gentle Skin Cleanser or Aquanil, rinse thoroughly, and dry well."
I have Aquanil, it works well, but my sense of smell is not as acute as my wife's, though she has never mentioned any odor coming from my tracker. Have you tried those?
Just my 2¢.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
10-09-2016 17:41
10-09-2016 17:41
05-28-2017 08:29 - edited 05-28-2017 08:30
My Fitbit fell apart before it stopped working--due to daily wear, not water damage. The clip on the side of the Fitbit fell off, making it impossible to plug into the charger, but my iPad kept on reading the unit until the charge was finally drained. I showered with the Fitbit until the day the clip fell off.
Best Answer06-29-2020 15:54
06-29-2020 15:54
Leave it on while your in the swimming pool. Chlorine kills off the smell no problem
Best Answer06-30-2020 00:01
06-30-2020 00:01
Wipe it down with a baby wipe daily?
Common sense needs to come into play about cleaning your tracker
Wendy | CA | Moto G6 Android
