01-04-2020
11:43
19:57
01-04-2020
11:43
19:57
My heart rate is not working on the clock face and there is a solid red light on the back of my fitbit
i have restarted it several times
01-04-2020 13:39
01-04-2020 13:39
Try a Long Restart:
CHARGE 3 LONG RESTART
Connect the device to the charging cable.
While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
The device turns off.
The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
Remove the device from the charging cable. The device shuts down.
Important: Plug the device into the charging cable again.
01-05-2020 09:52
01-05-2020 09:52
01-05-2020 10:59
01-05-2020 10:59
Contact Customer Support.
