10-31-2018
19:50
18:22
10-31-2018
19:50
18:22
Hi,
I am using my Charge 2 to track my spinning workout using the exercise shortcut. One thing that I am not able to log is the distance covered during my spinning workout. I am using the Fitbit Android App. Is there some way to manually edit the workout to add the distance? Please help.
Thank you
MT
11-02-2018 10:47
11-02-2018 10:47
Hey @mt13, welcome to the Community! If you are using the Multisport mode to track your Spinning, it won't track distance. The only things that are recorded are: time, heart rate, calories burned and duration. If you'd like to add distance to your activity, you can manually add it by following these instructions.
Hope this helps!
Best Answer05-08-2020 10:12
05-08-2020 10:12
Hello, the link provided doesn't show how you can edit a logged spin entry to update the calories. How can we do this?
