10-16-2018
11:09
15:06
10-16-2018
11:09
15:06
I was hoping the recent firmware update would fix the stair counting on my Charge 3, it hasn't.
My Charge 2 wasn't perfect, it often missed flights, but it would always register _something_. With my Charge 2, I could go up 6 flights of stairs and sometimes it would only register 3. It was annoying, but somewhat infrequent, so I just lived with it. With my Charge 3, I can go up the same 6 flights of stairs and get nothing (my stair counts are what my Charge 2 would have registered).
Before I went to lunch I had done 40 flights of stairs, my Charge 3 said I had only done 23.
Is there a chance this can get fixed? I can accept the same performance as the older model, but this is a major step backwards.
I'd like to stay in the Fitbit ecosystem, but if this cannot be fixed I will have to return it and move on to something else.
Thanks,
Brian
04-20-2019 06:12
04-20-2019 06:12
It doesn't count "stairs", it counts "floors". Fitbit's definition of floors is 10 feet of elevation gain. You have to be moving your arm while this is happening, thus why when you're on an airplane or an elevator, you don't get hundreds or thousands of floors.
However, the barometer used in Fitbits is sensitive to wind and air pressure while you're moving. This is why you'll get wildly inaccurate floor counts sometimes. This paragraph from this help article explaining floors also touches on the changes of barometric pressure:
HOW DOES MY FITBIT DEVICE COUNT FLOORS?
Fitbit devices that count floors have an altimeter sensor that can detect when you're going up or down in elevation. Your device registers one floor when you climb about 10 feet at one time. It does not register floors when you go down.
Fitbit devices do not count the elevation gains simulated from a StairMaster, inclined treadmill, or other stationary exercise equipment. Your device uses changes in barometric pressure to detect elevation change, and therefore requires that you physically change elevation in order to properly record floors.
I personally think the barometer is overly sensitive. I know that on my runs, I do change some elevation, but not enough for 40+ floors that I'll get on a windy day. Or the 11 floors I get in the shower.
I would assume, meaning I don't really know, that floors counts were originally useful for hiking with your Fitbit, so that hikers could gauge elevation gain.
06:29
08:53
04-20-2019
06:29
08:53
@hmthrman I don't work for Fitbit, I'm just someone who loves Fitbit devices, that is all.
I'm not trying to "convince" you of anything, merely offering an explanation of why your Fitbit doesn't always count floors correctly. Barometers use air pressure, they are sensitive. This is how Fitbit has chosen to measure floor counts.
It's not going to be perfect. Sometimes it's right, sometimes it's not because of barometric pressure conditions. It just is what it is. You can either accept it and enjoy your device for what it is (like I said, floor counts don't affect your steps or calories) or move on to something else, maybe a device without floor counting capabilities.
Best Answer04-20-2019 06:41
04-20-2019 06:41
I received my Charge 3 for Christmas and it counted floors fairly correctly until March 28th. Now it is counting 30 or more floors a day and my life is still the same. Why is it that it worked before but not after March 27th? I have reset it several times but this has not helped.
Best Answer04-20-2019 07:30
04-20-2019 07:30
Is there anything the Charge 3 is doing accurately?? Mine over counts steps by the thousands, over counts active minutes by a lot, over counts stairs by a lot. I did not buy it to be 100% accurate but close.
Here is a screen shot. I walked about 5 miles this day. Should have been about 10000 steps and roughly 60 active minutes. I climbed zero stairs.
Do do you think this device is worth the $130 spent on it?
04-20-2019 17:15
04-20-2019 17:15
20:48
09:47
DavideFitbit
04-20-2019
20:48
09:47
DavideFitbit
Chuckling....I went back to the Flex 2 because it does not count floor
climbs, although I would love to be able to add them, living in a 3 story
home. I love those stair climb badges and the climbs are good for fitness.
It is just annoying to know you did 15 stair climbs and have it register 0
or 1.
The original Fitbit and the One all did climbs pretty accurately.
Because I can adjust other activity, count water glasses, I would love if
Fitbit would just let me and others adjust the stair climbs as it is part
of my fitness!
Moderator edit: removed personal info
04-22-2019 04:39
04-22-2019 04:39
Best Answer04-22-2019 04:43
04-22-2019 04:43
Best Answer04-22-2019 10:00
04-22-2019 10:00
11:49
09:30
04-27-2019
11:49
09:30
@s615 Welcome to our Fitbit Community and It's great to see you here @RogerF ! I'm sorry for the late response. However, since your Charge 3 trackers are still unable to track your floors accurately, I'll send your cases to our Support team so they can investigate further and provide a solution.
By the way, thank you for trying the recommended troubleshooting steps. I totally understand how frustrating this is for you and I appreciate your feedback. You will receive an email from our Support team soon.
@SunsetRunner I was able to get in touch with our Support team and was told that you'll receive instructions via email soon. Please keep an eye on your email account.
@scparks @KataBomm I truly understand how you feel and your feedback is greatly appreciated since this helps us to keep improving.
Best Answer04-27-2019 11:59
04-27-2019 11:59
Best Answer04-27-2019 14:11
04-27-2019 14:11
08:01
09:29
04-29-2019
08:01
09:29
Hey, thanks for your participation in the Community.
@KataBomm, I appreciate the feedback provided about your experience with the Charge 3. If in the future there is anything we can help you with, let us know.
@Bev71, is your Charge 3 counting extra stairs or not counting them all? About the notifications, I recommend taking a look at the help article: My Fitbit device isn't receiving notifications from my phone and follow the instructions provided there. Just keep in mind that, we are moderating this thread for users who are having issue with their stairs count. If you are experiencing other issues or have a feature suggestion or improvement, I encourage you to find a similar thread, check out the feature suggestion board or start a new thread.
I will see you around.
Best Answer06-09-2019 11:58
06-09-2019 11:58
I am having the same issue. I have done about 6 flights today and it says I have done 19! I would like it to be more accurate if possible. Is anything being done?
Best Answer06-09-2019 14:00
06-09-2019 14:00
Best Answer07-13-2019 10:54
07-13-2019 10:54
I upgraded to the Charge 3 in June from my cracked screen Charge 2. The staircase feature is a deal breaker for me! While the Charge 2 was sometimes inaccurate, like you, this doesn't count anything many times! I realize that when I am not home, maybe the 10' is an issue, but at home, with the same staircase that the Charge 2 recognized. So, I chatted with Support and they sent me a new one. Guess what? Same issue and it doesn't help to do any of the recommended reboots.......I really am sorry to have to say goodbye to Fitbit, but this is going back.
Best Answer07-13-2019 11:18
07-13-2019 11:18
Best Answer07-13-2019 16:00
07-13-2019 16:00
07-13-2019 17:41
07-13-2019 17:41
Well said!
Best Answer09-11-2019 18:57
09-11-2019 18:57
I climb wind towers for a living. My charge 3 was counting floors. Inaccurately but was counting. The past 2 days I've been up 4 towers. Charge 3 recorded 3 floors yesterday and 0 today. Typically in a 2 tower day I'd see a number near or above 60. Why has it stopped counting?
