03-27-2018
14:15
18:54
03-27-2018
14:15
18:54
Hi! Although my steps are syncing when I go to my friends list they haven’t updated. Ive tried turning off my iPhone and iPad, updating Fitbit and syncing several times over the day, but steps on friends list have stayed the same. Help please!
03-29-2018 05:37
03-29-2018 05:37
Welcome to the Fitbit Community @EvieD! Thanks for bringing this to my attention and thanks for the steps you've already tried. Nice way to go!
It's possible the app is not updating the information correctly. To refresh the information, please try the following:
If the issue persists, I'd suggest to check this on the web-based Dashboard to see if your friends list is not updating in that platform either.
If the list works on the web-based Dashboard, please send me screen of what you're getting on your Fitbit app so I can go from there.
Looking forward to your response!
Best Answer07-17-2020 19:41
07-17-2020 19:41
I am having the same issue. My steps update in the app on the “today” screen, but my steps don’t update with the new 7day total on my friends list. I followed your suggestions and it still didn’t work. The dashboard online shows my 7 day total but the app won’t update. I took screenshots and can send them to you if that helps. Thanks!
09-26-2020 13:11
09-26-2020 13:11
Here it is September 2020 and this still happens. I can't get my steps to update on the Friends page. It has not updated all day. I shut down the app every time I open it to use it and reboot the iPhone. I even updated the app from the app store. Reopened the app and still, the same number of steps are showing for me. If there is an algorithm that only allows a certain number of updates per day then fine but we should be made aware of this. Otherwise, this is clearly a server-side bug and should be fixed.
09-30-2020 15:19
09-30-2020 15:19
I’m having the same issue.
01-29-2023 08:35
01-29-2023 08:35
Similar issue just popped up for me in January 2023: my friends’ steps update but mine don’t. Closed the app, reinstalled the app, no change. Any suggestions?
02-03-2023 07:32
02-03-2023 07:32
Same issue as Brett. I got my weekly summary to find I have no steps reported compared to my friends (for the most part I don’t watch the community area but enjoy seeing it on the email).
I restated the app and my tracker.
I logged out of the app, I’ve uninstalled, and re-installed the app. No change.
Best Answer02-06-2023 07:41
02-06-2023 07:41
Found on another discussion:
click on your picture
scroll past Set up device to
Social and Sharing
under privacy, change average daily steps to allow friends to see it
Best Answer02-06-2023 13:00
02-06-2023 13:00
Thanks "meroad" , worked perfectly as you described !
