08-25-2019
09:45
13:33
08-25-2019
09:45
13:33
My Fitbit Charge 2 is struggling to sync to my Fitbit App even though it is in the same room as me when i am syncing it. So I was wondering if anyone else is having the same problem as me and if there is a way to sort the problem because it is Rather annoying having to try to sync it multiple times just to get it sync to the app.
08-25-2019 11:36
08-25-2019 11:36
I have had problems all day, have you heard anything else? Could do with advise on this?
08-25-2019 17:01
08-25-2019 17:01
I haven't heard anything else about the syncing problem yet. But if I do i will let you know. I know how you feel it is very annoying when the Charge 2 just won't sync very easily I normally eventually get it to sync but it takes multiple trys.
08-25-2019 17:15
08-25-2019 17:15
My band won't sync either 😞
08-25-2019 17:28
08-25-2019 17:28
Mine won't either today
08-25-2019 18:05
08-25-2019 18:05
My fitbit was syncing esrlier and it has stopped as well. Hopefully they will answer with what is going on
08-26-2019 04:23
08-26-2019 04:23
I ended up resetting my bluetooth connection and it works fine
08-26-2019 04:50
08-26-2019 04:50
I turned my phone off last night and when I started it back up this morning all is good. Thanks
08-26-2019 17:01
08-26-2019 17:01
How did you manage to reset your Bluetooth. Because I want to try that to see if it works for me.
