09-29-2016
10:15
20:15
09-29-2016
10:15
20:15
Been having trouble setting up my fitbit charge HR. fitbit. it gets stuck on "connecting to fitbit" after entering the number I see on my Charge HR. I see others have the same issue. I have iphone 5s, iOS 10 and updated my fitbit app. All I got from tweeting @fitbitsupport was to try a link on setup troubleshoots and to post on this forum. I've tried all the troubleshoots multiple times resetting Fitbit and Phone and still keep getting stock at "connecting to fitbit". This is really frustrating and I think I'm not alone if you look on twitter.
07-18-2020 18:52
07-18-2020 18:52
Did that... Still does not connect
Best Answer07-18-2020 19:04
07-18-2020 19:04
What screen? I tried the screen on my phone and nothing...... You mean the screen that it's stuck on?
Best Answer03-07-2021 13:15
03-07-2021 13:15
ok - Where on the "stalled screen" did you hold your thumb and for how long? Fast forward to 2021 and I never this problem until very recently. I have tried several times and ways to get it to sync and I was able to last week, but this week - nope.
Best Answer03-07-2021 13:29
03-07-2021 13:29
Finally, it worked. I just waited much longer than I thought I should possibly have to wait, but it finally went to the next screen.
Best Answer01-15-2022 07:07
01-15-2022 07:07
I know this is an old thread - but I also ran into this problem on my iPhone (6s running iOS 14). The app seemed to be stuck on “connecting to Fitbit” forever. Others have mentioned placing your thumb on the screen. For me, what worked was placing my thumb on the home button of my iPhone (which is old enough the have a home button), just like I do to unlock it, or make a payment via ApplePay, or verify that I want to install an app. It might require a finger instead - it’s probably whichever fingerprint the phone has been configured to use for security. As soon as I did that, the Fitbit app progress bar whizzed across the screen and the pairing was successful. I don’t know why this isn’t documented in an obvious place.
08-28-2022 17:14
08-28-2022 17:14
You are a hero tonight, friend. I was on my seventh attempt to re-pair my versa2 with my iPhone 13 mini… the thumb trick on the connecting screen worked. (Why did it work? It makes absolutely no sense, but it did!!!) Thanks a million.
10-14-2022 00:20
10-14-2022 00:20
Keep the Device within the Bluetooth range Most of the time, you suddenly face connection errors if you keep the smartphone or fitness tracker beyond the Bluetooth range.
Bluetooth Connectivity Issue
Reboot Fitness Tracker and Smartphone
Update your Fitbit App to the Latest Version
Check for Fitbit Tracker Software Update
Regards,
Will
Best Answer10-24-2022 08:42
10-24-2022 08:42
Hi I've tried everything mentioned in this thread, including updating the app and configuring wifi/bluetooth and it STILL get stuck in connecting for 20+ minutes when I'm trying to sync my device that has been fine for the past 7 months. There is nothing wrong with my device. This is ridiculous. Fitbit will never get another cent from me.
01-31-2023 11:50
01-31-2023 11:50
I finally got mine to connect after several hours of messing with it. I think it finally connected when the iphone security finally displayed and I had to enter my PIN. Something happened at that point to where it connected.
