07-31-2019
13:57
14:11
07-31-2019
13:57
14:11
Any advice on how I can make my fit bit connect with my phone through syncing as I can't get them to sync together for a bout a week now through bluetooth
08-01-2019 02:02
08-01-2019 02:02
The usual things to try when you get syncing issues are:
These have always worked for me when I’ve had problems but others have found other steps that worked for them. For example:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
