Sync to new phone
How do you sync Fitbit to a new phone
2 REPLIES 2
On your new phone you just download the fitbit app and login using the ID and password you used for the app on your old phone (you don't need to set up a new account or go through the setup process again).
If your old phone is still around then make sure you delete any connection to the fitbit in its bluetooth settings as this could block connection to your new phone.
If you have any issues then you may also want to check that your new phone works with fitbit at www.fitbit.com/devices
Thanks for your help. I needed to turn off Bluetooth from old phone.
