02-15-2017
12:22
10:13
02-15-2017
12:22
10:13
How do you sync with Weight Watchers app to transfer acitivity?
02-15-2017 12:51
02-15-2017 12:51
Here is an article to help you set it up
http://help.fitbit.com/articles/en_US/Help_article/1570/?q=weight+watchers&l=en_US&fs=Search&pn=1
Needs to be done on Computer. I see no way to add it on the phone
Wendy | CA | Moto G6 Android
03-20-2017 18:10
03-20-2017 18:10
Go to WW subscribers home page, log in. Go to profile icon in top right corner and click SETTINGS.
Then click ACTIVITY tab.
Then click CONNECT TO A DEVICE OR APP.
Then select FITBIT and continue.
Then log in to FitBit with your account credentials.
You should be done.
You can also Google "10 Easy Steps to Syncing your Fitbit with the Weight Watchers App"
09-17-2017 17:15
09-17-2017 17:15
The steps on my FitBit are never the same as they are on my Weight Watchers... The FitBit is always higher.
10-18-2017 07:46
10-18-2017 07:46
On the Fitbit app, choose All Day Sync. That worked for me.
12-17-2017 10:36
12-17-2017 10:36
This isn't working for me. I go to the WW online site, go to Settings, add a device, select Fitbit, select which Fitbit data I am willing to sync with WW, click ALLOW, and it takes me back to the Weight Watchers settings page where it says "no device connected".
12-17-2017 10:41
12-17-2017 10:41
@PiperG Then you need to contact WW its on their end not Fitbits
03-13-2018 13:20
03-13-2018 13:20
I have an LG G5. I am not sure it is the same for all devices.
From the WW mobile app go to settings, then activity settings, then activity sync (you will need to wait as it takes a minute), then device, then fitbit (again you have to wait a minute), you will then be prompted to log in to fitbit, select which items you want to sync by clicking on the box, then you will be prompted to sign into WW, click launch app, it should then hopefully be synced!
03-13-2018 19:01
03-13-2018 19:01
05-18-2018 07:56
05-18-2018 07:56
I connected the fitbit to the ww app but when I get to the "all-day sync" part in the fitbit app, I get the message "Bluetoothe Pairing Failed. Call Notifications and All-Day Sync are disable for now". I made sure it was on wifi and bluetooth was enabled on the phone. What is wrong? Do you think uninstalling and reinstalling the app would help?
12-11-2018 12:15
12-11-2018 12:15
How do you sync Change 3 with WW app?
12-11-2018 16:33
12-11-2018 16:33
Have you followed the steps (above) that awkwardpony listed to get the two apps to talk to each other?
If you have, just open the WW app, click on the activity tab at the top, scroll to the bottom and tap "Sync with your Fitbit app".
01-27-2020 19:29
01-27-2020 19:29
PiperG, I’m having the same trouble you posted earlier: following the steps but still end up back at “no device connected” after logging in and “allowing” WW access. What did you do differently to get the. To talk?
01-28-2020 06:03
01-28-2020 06:03
Geez...I'm sorry, I don't remember. But, it has been working seamlessly for the last year!
