Text messages and calls not showing up on my Charge 2
My Fitbit doesn't notify me of a text message or call. How to I fix this?
8 REPLIES 8
@MeganG0585 Welcome! It's great to see you around!
Let me help you with your Charge 2 not getting notifications. Which phone are you using? Is it compatibleYou can try the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Let me know how it goes.
Alvaro | Community Moderator
If you haven't done the software update,
(from October 2019)that doesn't work, you don't get call/text notifications
I have done the update. Everything worked perfectly fine before...
Same here. Messages/calls were coming thru just fine, so I know my notification settings are set properly. But for a few days now, the notifications stopped coming thru. I reset my Charge 2. I unpaired and re-paired. Reset my settings. Still, nothing. Is this a Fitbit glitch??
Yes, I think it’s a major glitch.
I have a Samsung S7 Edge. This still did not work for me.
Hello did this issue ever get fixed? I am having the exact same problem with my Versa 2. Call notifications work but text messages don’t. I have an IPhone. Thanks!
Eventually mine starting working again... calls and text notifications. But they still fail to appear sometimes. 😑 Since it's been a little more consistent, I'm guessing that when they don't appear, it's a connection issue - with the Sprint / T-Mobile merger, my service has been suffering the last couple of weeks. Good luck with yours, hopefully you get the text notifications to work!!
