10-25-2017
19:25
09:26
10-25-2017
19:25
09:26
How do I get my fit bit and my phone linked back up so when I get text messages they come through on my fit bit. I have the Charge 2 fit bit. Can anyone help me so that I can get this set up again from my phone to my fit bit again. I enjoy that feature. I had it then it went away. I would like to get it back again
Thank you Peggy
Moderator edit: Title
10-25-2017 20:43
10-25-2017 20:43
Check you don't have notifications turned off. Holding in the side button a few seconds toggles notifications off and on. Sometimes it can get accidentally get turned off when pressing the button too long.
10-25-2017 20:43
10-25-2017 20:43
10-25-2017 20:57
10-25-2017 20:57
Same issue. Have done all of the fixes suggested on line/forums with no luck. I have the iPhone SE, notifications are turned on, latest firmware, chatted with Fitbit help today and they had no suggestions. Had me send them screen shots of my phone and Fitbit settings and they were going to escalate the issue. I’m thinking it is a firmware update bug. Thoughts?
10-26-2017 15:25
10-26-2017 15:25
my notifications button is always on. So it's not that. I have checked that all the time. So not sure what is the problem
11-08-2017 11:45
11-08-2017 11:45
Been there. Done That. No help. What's next????
Best Answer11-08-2017 13:23
11-08-2017 13:23
11-11-2017 09:45
11-11-2017 09:45
It was quite nice when it worked. Pretty much a big reason why I got this particular Fitbit
11-11-2017 12:48
11-11-2017 12:48
13:05
07:42
AlvaroFitbit
11-11-2017
13:05
07:42
AlvaroFitbit
I have same issues, as did my sister. She got her charge 2 a few weeks before I did and recently the notifications just stopped. A few days ago mine also stopped. I've done all recommended "fix its". Does not work.
Moderator edit: format
11-11-2017 14:12
11-11-2017 14:12
There are 3 versions of the app for 3 different phones, and this question is about the phone app, probably not the Charge 2. We would be able to give specific help if we knew the model of the phone.
If it is a Charge 2 problem make sure that the Charge 2 is not in its DND mode by holding on the button while viewing the watc-.
19:43
07:43
AlvaroFitbit
11-11-2017
19:43
07:43
AlvaroFitbit
I don't know. But it's not coincidental that both our charge 2's stopped working almost a year later.
11-11-2017 20:42
11-11-2017 20:42
I have the iPhone SE with IOS version 11.1.1
My Fitbit - Charge HR firmware version 22.55.2
Fitbit app for iPhone
I still don’t receive text/phone notifications on my tracker. I was told that it is a FitBit app issue that they are working on?!
11-12-2017 02:12
11-12-2017 02:12
Moi aussi c'est au bout de 1 an tout juste que mon charge 2 ne veut plus synchroniser et s'associer avec mon téléphone.
Best Answer11-12-2017 11:20
11-12-2017 11:20
11-12-2017 12:34
11-12-2017 12:34
@Rainydaye3 I can't think of any reason Charge 2 wouldn't vibrate with notification. Maybe see if you can get a "reminder to move" vibration at ten of an hour, or set an alarm to check if it vibrates.
Best Answer11-12-2017 13:16
11-12-2017 13:16
I got mine working again. Not sure how I did it but between talking with the help desk and doing a few things on my own. Mine has been working again. Glad I got it working.
11-12-2017 13:54
11-12-2017 13:54
Best Answer11-12-2017 18:13 - edited 11-12-2017 18:14
same problem here! what Fitbit is doing about it?
Best Answer11-12-2017 23:20
11-12-2017 23:20
Best Answer11-12-2017 23:35
11-12-2017 23:35
