10-25-2017
19:25
09:26
10-25-2017
19:25
09:26
How do I get my fit bit and my phone linked back up so when I get text messages they come through on my fit bit. I have the Charge 2 fit bit. Can anyone help me so that I can get this set up again from my phone to my fit bit again. I enjoy that feature. I had it then it went away. I would like to get it back again
Thank you Peggy
Moderator edit: Title
03-07-2018 15:01
03-07-2018 15:01
Best Answer05-22-2019 19:39
05-22-2019 19:39
Holding the button on the fit bit down for a couple of seconds worked for me. Thanks alot!
05-23-2019 05:40
05-23-2019 05:40
Best Answer05-23-2019 08:21
05-23-2019 08:21
Best Answer05-23-2019 11:12
05-23-2019 11:12
Best Answer05-23-2019 14:02
05-23-2019 14:02
You setup the tracker to your account, then the Fitbit app will ask permission to connect(pair) the tracker. This pairing can not be done by the user through the phones bluetooth option.
Best Answer05-28-2019 09:14
05-28-2019 09:14
Best Answer05-28-2019 09:15
05-28-2019 09:15
Best Answer05-28-2019 09:34
05-28-2019 09:34
Best Answer05-28-2019 17:53
05-28-2019 17:53
Hopefully someone who understands apple will stumble across this thread and help out, or I can move the apple people over to the apple forum.
18:11
10:06
05-31-2019
18:11
10:06
Hey guys! I'm here to provide assistance with the notifications concern you're experiencing, my apologies for the delayed reply. Welcome to our Community Forums @AnneHJ! also, it's nice to see you participating in our forums again @Rainydaye3 @luckyjo and to see @Rich_Laue helping in this thread, your willingness to help is always appreciated!
@Rainydaye3 Can you please let me know if your notifications concern was resolved after taking in consideration the information that was shared by @AnneHJ? Since you changed your mobile device, you'll need to connect your new mobile device with your Charge 2, please take in consideration the information from our help article: How do I get notifications from my phone on my Fitbit device? and let me know how it goes. Also, in regards the battery of your device, please check our tips and recommendations to improve battery life here.
@luckyjo thanks for trying some of the troubleshooting steps that were provided in this thread. If you haven't already done so, can you please review the information from our help article: My Fitbit device isn't receiving notifications from my phone and let me know how it goes after taking in consideration all the requirements and steps that are specified there?
@AnneHJ I'm happy to know that your concern was resolved, thanks for troubleshooting your device and for providing some suggestions that might help other users too. Don't hesitate to contact me back if you need anything else.
I'll be around.
Best Answer05-31-2019 18:35
05-31-2019 18:35
Mine has randomly stopped working too. I have a Samsung A8 and it worked perfectly but now it's not. I've tried all the suggested options online I can find and still no help. My fitbit is less than 12 months old.
Best Answer05-31-2019 18:59 - edited 05-31-2019 19:03
I'm not sure which of the suggested options you have tried are.
Logging out/in?
Through the app disable then enable notificatins?
,Checking the settings in the app and permissions on the. phone?
Phone settings / notifications / is Fitbit allowed?
Phone settings, apps, fitbit, notification enabled?
Me settings apps / Fitbit, / permission allowed?
Does the Charge 2 show up as a trusted device in the Bluetooth?
I assume that the help files on notification has been reS
Best Answer05-31-2019 19:05
05-31-2019 19:05
Best Answer06-01-2019 03:51
06-01-2019 03:51
I've done all of the above and I've uninstalled the app, deleted my fitbit from the app to re pair it, reset the fitbit etc and it just isn't working.
The tracker isn't showing in my bluetooth list no.
Best Answer06-01-2019 13:41
06-01-2019 13:41
Best Answer06-01-2019 16:10
06-01-2019 16:10
Until the tracker shows on Bluetooth list notifications probably will not work.
With the setup of the tracker, the app should have asked for permission to connect the tracker to the phone.
Best Answer06-01-2019 17:04
06-01-2019 17:04
It does ask and it says it's getting ready to connect then it returns to the main app screen with no notifications whether it's done or not but obviously it's not.
I have bluetooth connected to other things so it's not my phone...
Best Answer06-01-2019 17:11
06-01-2019 17:11
The other BT things are probably the old BT and get connected by the user through the phones BT menu. Fitbit uses low energy BT and the app needs to set up the connection.
Try logging out of the app and log back in. My android then asks to set things up. And then send a test notification.
I'm assuming notifications are turned on, on the tracker.
Best Answer06-01-2019 17:14
06-01-2019 17:14
I've done this multiple times hence my frustrations. I am quite "tech savvy" so understand the functionalities it's just not working!!!
