06-17-2020 20:39 - last edited on 09-16-2020 10:17 by MatthewFitbit
I have a charge 3 and now the screen is too dim that I can’t even see the settings section to try and increase the brightness. I have tried a soft reset, but that didn’t work
07-01-2020 15:18 - edited 07-09-2020 15:00
Welcome to the Fitbit Community @Mkuck.
I'm sorry to hear that the display of your Fitbit Charge 3 is too dim. Thank you for the information provided and for trying to resolve the issue before contacting us.
In addition to the restart, you can perform a long restart by doing the following:
If you have any question, please let us know.
07-07-2020 07:47
07-07-2020 07:47
My screen is NOT bright at all. I have gone to setting and changed the screen brightness to auto, normal etc. but is does not change change the brightness. What else can I do?
07-09-2020 14:31
07-09-2020 14:31
Thanks for the update @Mkuck.
To evaluate this situation, I created a case with Customer Support. Please check your inbox on the next days. They will let you know how to proceed as soon as possible. Thank you for your patience.
I moved your last post to this conversation to keep the Community organized.
Please let us know if you have any question.
07-25-2020 07:56
07-25-2020 07:56
I am having same issue. Is there a way to brightness screen thru the App?
Frustrating 😞
07-25-2020 07:57
07-25-2020 07:57
Please let us know your solution.
07-25-2020 09:51
07-25-2020 09:51
Had my Charge 3 for just over 12 months. Over the last couple of weeks the display has been gradually dimming down. Set on normal brightness but now barely readable.
If it was a cheap Chinese knock off I’d not be surprised but Fitbits aren’t exactly cheap. Guess I won’t be buying another Fitbit.
07-29-2020 19:32
07-29-2020 19:32
Thank you for visiting the Fitbit Community @LisaS73 @SunsetRunner.
@LisaS73, the only way to change the brightness of your Charge 3 screen is from the tracker itself. For more information, please visit this article.
@LisaS73 @SunsetRunner, I just created a case with to Customer Support for each one of you, to provide further assistance. Please keep an eye on your inbox. They will get in touch with you on the next days.
If you need assistance, please let us know.
11-25-2020 12:23
11-25-2020 12:23
Didn't work ... I still can't see my screen to increase brightness. How can I fix this?
11-25-2020 12:45 - edited 11-25-2020 13:29
I am having this problem as well. The screen got dimmer and dimmer over a few weeks and now it's completely black. I haven't been able to get it to light up at all in the past couple of weeks. I've tried the long restart, but it didn't fix the problem. Fitbit, please help.
Edited to add: I've only had this Fitbit for 1.5 years. My previous Fitbits have lasted way longer than this!
