01-11-2019
06:22
13:05
01-11-2019
06:22
13:05
Hi, my beloved One has just died, and I am looking for a replacement. I don't do wristbands. Has anyone found a third-party clip for the Charge 3 (or 2)?
I've only found this little pouch, which still looks quite bulky. I'd really like a silicone one like the One had, or something similar. https://www.amazon.co.uk/holder-fitbit-fitness-tracker-wristband/dp/B01MA1WNOU
**I know the HR won't work, but I don't plan to use that anyway. I'm also aware that the step count may be different, although from reading the forums it sounds like it's more accurate anywhere but the wrist, whatever the moderators may say.**
Thanks!
08-17-2019 16:54
08-17-2019 16:54
It never occurred to me to look at a Garmin clip on. Thank you for the great idea.
Best Answer08-17-2019 17:04
08-17-2019 17:04
understand why you say the watch won't work. You just reset it to your Bluetooth and it will work. Only you can't have 2 Charge 3's on one account at the same time. Which I feel doesn't make sense because that Alta HR I gave my daughter, can run both. She just changes them when the battery goes low so she always has one fully charged. You can buy the silicone bands on Amazon. It came with a large one. Some people use it on their ankle. Insist that they get better steps accuracy. These you can get 3 bands different colors. Order large as that's what came with it.https://www.amazon.com/Wepro-Replacement-Compatible-Waterproof-Wristband/dp/B07J5JLYD4/ref=sr_1_11?k...
Best Answer08-25-2019 18:53
08-25-2019 18:53
My One has just died as well. I knew it was on its way out (button wouldn't press anymore to show display, but it still tracked; now it's not tracking/charging anymore), and now I'm not happy that they not only discontinued the One, but also don't have a good equivalent. Closest is the Charge 3, but I do *not* want a bracelet. Thanks for the pointers to the 3rd-party options for a clip that might work w/ the Charge 3.
I know they're not listening, even though they say they take feedback seriously (seen so many examples that prove otherwise), but I really miss my One and wish they'd bring it back or provide a true alternative. Better colors would be nice, too. ![]()
08-25-2019 19:43
08-25-2019 19:43
Raquel54, you are lucky yours still tracks...my and my husband have two bricks. I ended up with the Alta HR, which is fine, with little clip thing now. But I miss having the altimeter to count stairs........and it is now discontinued from what I can see......
Best Answer08-26-2019 05:04
08-26-2019 05:04
Best Answer08-26-2019 05:08
08-26-2019 05:08
If it helps any, I am actually liking the Charge 3 better than the One. I am now using small organza favor bags and my One clip to hold it in place. The with the Charge facing my skin, it has tracked my steps and exercise far better than the One and it's tracking all those hills I climb when I walk. It's not a perfect solution, but the bags last between 7 and 14 days and at a cost of $7 for 100 (Amazon), I think I'll be good for a while.
ATCG 100pcs 2x2.7 Inches Mini Organza Bags with Drawstring for Rings, Little Earrings, Jewelry Pieces, Wedding Favors Party Fovours Small Cute Organza Pouches (White)
Best Answer08-26-2019 10:21 - edited 08-26-2019 10:25
@Mtnlyte wrote:Raquel54, you are lucky yours still tracks...my and my husband have two bricks. I ended up with the Alta HR, which is fine, with little clip thing now. But I miss having the altimeter to count stairs........and it is now discontinued from what I can see......
It's not tracking anymore ... it did so for about 6 months w/ the bad button, but I just realized last night it was deader than dead. Wouldn't take a charge and it hadn't tracked for a few days. Off to the store today to get a new one. ![]()
08-27-2019 05:44
08-27-2019 05:44
Best Answer08-28-2019 18:30
08-28-2019 18:30
I wish you luck on finding a new One. They stopped making it nearly 2 years ago. Made me very angry. I can’t wear wristband types due to working in
manufacturing plant. Had to get the Alta HR with a clip similar to the One. Alta HR I hear had also been discontinued...,,
Best Answer08-29-2019 10:39
08-29-2019 10:39
Oh I found a One on-line ... but wasn't paying $300 for it. 😠
Ended up going w/ the Charge 3 (want to be able to count flights - can't believe most other Fitbits don't). I don't like the wristband type - it's uncomfortable and can tell it already over-counted my steps, but I plan on buying a 3rd-party clip to wear it in my pocket or on my underthings. Not worried about constant heart rate readings, and when I need them, I can put the band back on temporarily.
Also not happy that I can't sync the Charge 3 to my computer and iPad like I could with the One. *Why* do companies take away functionality when they "upgrade"??
09-24-2019 12:11
09-24-2019 12:11
How tightly does that IBREK clip product hold the Charge 3, given that it wasn't designed for it?
09-24-2019 15:28
09-24-2019 15:28
09-24-2019 16:25
09-24-2019 16:25
@MSKBM wrote:
It holds it really well. At first it is difficult to get it in the clip because it is so tight. Last about 18 months before it stretched out where I changed it out. Still held it but I was getting to do a 5k and didn't want to chance it falling out. Still have the clip just never switched it backSent from my Verizon, Samsung Galaxy smartphone
Oh - the thought of this makes me happy! I don't like wearing the Charge 3 as a watch (plus I think it give me too many steps), so I've been either putting in my pocket or tucking in waistband. Going to have to get me some of these. Thanks for point it out!
Best Answer09-24-2019 17:29
09-24-2019 17:29
Best Answer09-24-2019 19:02
09-24-2019 19:02
I ordered the Ibrek clips from Amazon, and as you said the fit was tight. I was concerned about the back of the Charge 3 (the heart rate sensor part) being scraped by the clip (the metal from the clip was not covered on the inside). I ended up returning them. I appreciate the suggestion though.
09-25-2019 05:41
09-25-2019 05:41
Best Answer11-22-2019 18:43
11-22-2019 18:43
I would also LOVE to have a clip option for Charge 3, or have Fitbit simply bring back the One! That is still my most favorite and versatile tracker. When you've got a good thing going - don't get rid of it guys!
My only concern with a clip on Charge 3 is that the sensor on the side of mine is hypersensitive and if I bend my wrist sometimes it pauses my exercise tracking 😞 So the clip would need to ensure your pocket (or anything else bumping against it depending on where it's clipped) won't activate the touch sensor.
01-06-2020 12:45
01-06-2020 12:45
How accurate is the alta with counting steps when worn on the clip?
Best Answer01-06-2020 13:00
01-06-2020 13:00
How is the clip working? On the amazon reviews one person said it did not fit the Charge 3. Were the step and floor counts accurate? I don't really need the HR function. I love my FitBitOne
01-06-2020 13:08
01-06-2020 13:08
Did you find a clip for the Charge 3?
