02-04-2019
19:13
12:53
EstuardoFitbit
02-04-2019
19:13
12:53
EstuardoFitbit
I have just had my first run with my new Charge 3. The "time in heart rate zones" shows zero for all categories (peak, cardio, fat burn). Also in the Exercise section, the heart rate shows a max of 79 bpm however in the Heart rate section it shows the time in heart rate zones at 37 minutes and at 170 bpm. I don't know why these should be different?
Hope someone can help. I have just moved back to Fitbit from Haiwei because I thought it would be more accurate. I really want to love my Charge 3! But heart rate is very important to me.
02-09-2019 08:31
02-09-2019 08:31
Hi @FitKatBit!
Thanks for your reply and for sharing what helped you out to resolve this inconvenience. Okay, that's good, note that if you ever user any other apps to track or log your activities, not all information may show on your account depending on the third party you use different details will show.
I'm glad to hear you're loving Charge 3, I'd say is one of the best trackers Fitbit has had. Regarding the experience that you're having with inaccuracy on distance when you aren't using GPS. I'd like you to check that your step count is being accurately tracked and also I'd suggest you to check on your stride length settings, if you set personal information here, your tracked information should be more accurate.
Let me know if you need further help!
02-07-2019 11:20
02-07-2019 11:20
Hi @FitKatBit! Welcome to the community forums!
That sounds strange, information should match on every tab on your account. I'd like to investigate more on this, for that I'd like you to provide me with some more information.
- Since when did you started to notice this difference on your information?
- How are you tracking your activities (SmartTrack, with the Fitbit app , manually logging activities, through a third party integration app) ?
- Could you provide some screenshots of the differences that you're seeing?
Look forward to your response!
02-08-2019 20:37 - edited 02-08-2019 20:41
Thanks for getting back to me. I deleted all the info from the Fitbit app that I could (exercises) and deleted the charge from the app (maybe overkill) and then started from scratch. The data from recent runs matches. To answer your question, I don’t use any other third party apps to record exercise, just synchronise the tracker to the Fitbit app.
I have got used to the Charge 3 and am loving it. Only issue now is the distance in my runs isn’t as accurate if I don’t use the phone GPS. I run the same path every day and it vibrates at 5 k a little short if I don’t have my phone GPS on. This was an issue with my other tracker, so I will learn to put up with that.
02-09-2019 08:31
02-09-2019 08:31
Hi @FitKatBit!
02-09-2019 13:07
02-09-2019 13:07
Thanks so much, that’s really helpful. I didn’t know I could adjust my stride in the device.
02-11-2019 12:52
02-11-2019 12:52
I'm glad to hear this was helpful for you @FitKatBit. You're welcome!
If you have any questions, let me know!
Happy stepping!
