02-22-2016
18:47
20:15
02-22-2016
18:47
20:15
Is anyone else as tired as me of the constant sync problems? I've had nothing but problems since I got this thing and it's so frustrating to have to reset, restart, try this, try that... how about they just make their product work or return our money. Mine hardly ever works correctly and I've spent hour and hours messing with this thing. Currently it's been a week since I could get it to sync despite dozens of efforts. If I contact customer support I get the same tired links that I've tried over and over... and then suddenly it'll sync out of nowhere and they're all "glad you got it to work, thanks for contacting us". Then the next week it starts all over. It's absolutely shameful.
02-23-2016 09:12
02-23-2016 09:12
Thanks for the steps and the hints. I have had this Fitbit for less that 3 months - it is my third - like most of the features but noticed that the problems started when the device started losing time. No problems until then. The problems quickly spiraled downward with more and more timing issues and also noticed that the battery was being used up much faster. I have tried all of the steps listed by Sweet Sausage and will post again if I have more problems. I did however find that my same step count etc. was present as soon as I registered the device again - hope this is not a drawback to the fix.
I also appreciate the text indicating what versions and iPhone and iOs you have as I was able to check this along the way.
Also would suggest you post the steps in the HELP area. I looked through all of the posts and found none of them to be helpful. I hope this works as the last two weeks have been very frustratin.
02-23-2016 09:45
02-23-2016 09:45
@hmbunbun wrote:
....... Also would suggest you post the steps in the HELP area. I looked through all of the posts and found none of them to be helpful.........
By all means if you notice these steps may be able to help others, paste the link below in that thread and mention that it happened to fix your phone/device connection problems for the time being. This link directly connects to the post with instructions. It appears to not work for everyone, but a few of us have had successes.
https://community.fitbit.com/t5/Charge-HR/Tired-of-syncing-issues/m-p/1197197#M101897
02-23-2016 10:57 - edited 02-23-2016 10:58
Well, in a more positive not for ME. Fitbit has reviewed my tracker activity and noticed that it isn't functioning as it should... Ya think?! Finally, they have agreed to send me a new one. Thanks Fitbit people. I will give them props for that although it did take quite some time for them to acknowledge the problem. Hopefully this one performs better. Good Luck everyone!
02-24-2016 12:54
02-24-2016 12:54
Nice job Sausage, it worked for me! Had to try it twice though, the first time it got into an infinite loop at the '"Finishing Up" stage but I gave it another try & for whatever reason it worked second time around (with Iphone 5s plugged into pc & sleep mode off, Charge HR just sitting next to the phone not charging).
Remains to see how long it will stay syched. Mine was fine for 2 months until I let the battery run flat.
02-25-2016 07:50
02-25-2016 07:50
02-26-2016 08:40
02-26-2016 08:40
Exact same frustrating problem!
03-05-2016 08:49
03-05-2016 08:49
It is quite troublesome.
My fitbit HR can't give me the right time. I can sync it every a few hours to keept it right. But many times, it can't get sync. Then a few days ago, the heart rate sensors didn't work. I tried do sync and restart the fitbit. It never worked. Then I tried to set it up as new device. Things get even worse. I can't connet the fitbit to my iphone or mac or the android phone. In the pair stage, after i type in the pair code, it never get conneted. Very disapported.
03-05-2016 09:20
03-05-2016 09:20
These steps resolved my syncing issue. I lost a couple of days of tracking but everything seems to be working now
03-05-2016 09:30
03-05-2016 09:30
Is this serious? I mean no disrespect, but these changes are a big deal. FitBit should notice that if you stopped in the middle, you could buy a competitor's product.
03-05-2016 09:59 - edited 03-05-2016 10:03
I too have tried all of the suggested fixes with no luck, even the fix suggested by Seaweed. Basically my
Charge HR is useless. Showing the incorrect time, will only sync randomly after multiple tries. In addition, the band has bubbled and is separating from the display top, bottom, and now on the side. I have never allowed it to get wet, so that is not the issue. This is a disgrace. I am waiting to hear from Fitbit, but have no confidence this will be rectified. It worked fine for about 6 months, then it went south. This has the earmarks of a bad software/firmware update.
03-05-2016 10:14
03-05-2016 10:14
Agreed...Nonfunctioning device... Fix the problem or refund our money.
I have rubbed my stomach and patted my head at the same time, spun in a circle during a thunderstorm, to no avail.
Last sync with customer service was over two weeks ago... who btw, thanked me for trying to fix the problem on my own. Anything to make your job easier, Bob! I'll pay for your product and I'll come up with my own solutions. What a great system!
I got this for Christmas and was so excited. Now they've turned me into a hater! I want to be on fitbit's payroll, as I spend so much time trying to get it to sync to my computer. In addition, the phone notificiation works sometimes, others not. I want my money back or something that works. Come'on fitbit. Step up to the plate!
03-07-2016 06:21 - last edited on 11-26-2020 16:43 by LiliyaFitbit
I also am still having problems. Each and every day and sometimes two and
three times a day I am resycing my Fitbit. I do wish there was more that
we could do. Is there anyone out there listening? I am beginning to think
not. It seems like an important firmware update would fix most of these
problems but I don't see them even being addressed. I still see only
version 2.19.
03-07-2016 08:11
03-07-2016 08:11
03-07-2016 08:18
03-07-2016 08:18
yep same story here
03-07-2016 08:23 - edited 03-07-2016 08:24
It's definitely annoying - I hate when technology doesn't work like it should! I've had my Charge HR since December 2014 and this is the first time that I've had any problems.
I was having major issues (sleep, HR weren't syncing at all, steps would sometimes sync but not often, syncing was reeeeeeeeally slow if it did work), but after trying a bunch of troubleshooting steps, I finally think I've got it working again. I don't know which one was the fix, but here's everything I did. Good luck!
And now I magically have HR data, sleep data, and my steps sync really quickly (within 20-30 seconds)! 🙂 I did this fix last Wednesday, and so far so good ... hope it sticks.
Hope this helps someone! I was ready to go back to my flex, but I love having the display screen and really didn't want to go back.
03-15-2016 10:08
03-15-2016 10:08
I have to admit that Fitbit apparently has addressed the syncing/incorrect issues. My Charge HR began functioning as it should for about a week. It began syncing properly last Sunday (3/7) and then received a firmware update (v122). I have had no problems since then.
02-20-2017 17:10
02-20-2017 17:10
I got the same problem I'm sick,of fitbit
02-21-2017 07:38
02-21-2017 07:38
03-13-2017 18:53
03-13-2017 18:53
Wow, this thread's been around for awhile. Sad to see so many people having issues with this product. As it turns out syncing issues are just the tip of the iceberg. We have now been through four since we originally acquired them. It turns out the bands like to separate from the body and cannot be repaired. That's right... we've had four... all four failed in under a year. Kinda speaks for itself doesn't it?!
03-13-2017 23:18
03-13-2017 23:18
Having same issues. Using Android phone. Had to do all suggestions again to get it to synch--finally have it synching again. Synch problem reoccurs constantly. Very frustrating. Wish I could recommend Fitbit but don't wish this problem on anyone!
