06-16-2016
15:39
17:01
06-16-2016
15:39
17:01
For some reason my fitbit has not been syncing all day. Which is weird because it was working perfectly this morning and now when I try to sync it it tells me that my 'tracker is not found'. Which is also weird because I've had my fitbit for over 6 months now and I've never seen that before. I've tried restarting my phone, logging in and out of my account on the app, I've tried turning off and on my BT. Can someone help me??
Moderator Edit: Updated Subject For Clarity
08-07-2016 14:42
08-07-2016 14:42
08-07-2016 16:41
08-07-2016 16:41
08-09-2016 09:56
08-09-2016 09:56
I unpaired it from my account and then added it back. I did lose all my data. What's weird is that it saved my steps from yesterday. Nothing prior. Alarms were gone. I'm totally bummed. But, it's working again... so....
08-09-2016 10:31
08-09-2016 10:31
08-09-2016 13:30
08-09-2016 13:30
08-17-2016 18:53
08-17-2016 18:53
Mine isnt connected but Its not letting me connect it again,
09-04-2016 07:34
09-04-2016 07:34
I finally got my fitbit setup!! It is now synced. I am so freaking happy right now. I can't wait too see how well this works.
09-04-2016 07:45
09-04-2016 07:45
09-05-2016 08:27
09-05-2016 08:27
Hi everyone, I know some of you have posted here a while ago and some are new faces, so I would like to start with giving you a warm welcome to @Jeffner1, @Jennbryan, @DFINNBIT and @TheGodlyBeast.
Also thank you for all the input and help from @NikIce who were able to resolved the issue, as the recommendations of @missj0198 and @Shelby2010.
When this issue is happening, the best to try is what was recommended here or as it were tried by @JockoT and @Shelby2010; is to remove the tracker or just set it up again on your existing account. But just to clarify if the steps from that day has not synced, exist the small chance to loose your steps from that day as it happen to @DFINNBIT. So becareful with this.
@Jneil3817 I was reading you received a replacement, but were not able to set up the tracker again. I wonder how it goes so far? because its been a few weeks since you commented on this; so out of curiosity I would like to give follow up with you. If the issue persist as is the case of @millertime24 and @TheGodlyBeast I recommend to perform a restart on your trackers.
1. Plug your charging cable into the USB port and insert the other end into the port on the back of your Charge. Your Charge will begin charging.
2. Press and hold the button for 10 to 12 seconds until you see the Fitbit icon and a version number of the firmware
3. Let go of the button.
4. Unplug your tracker from the charging cable.
Make sure you are running the latest version of the app by looking your apps either on Google Play or iOS app store. Once you have reviewed this, please follow the steps I have shared on this other post. I explained the steps to set up a tracker with as an existing user with the app or the computer, but feel free to try both in case your mobile app is failing.
Let me know if I missing something and see you around if you need more help.
09-05-2016 08:53
09-05-2016 08:53
09-17-2016
15:03
07:35
JuanJoFitbit
09-17-2016
15:03
07:35
JuanJoFitbit
I am having the same issue today. Is there a way to sync to the laptop and bypass the phone altogether?
I'm in your shoes today. My sister has been having the same issue for about a week. Wondering if this is an Android glitch as a lot of the posters are doing so from their Galaxy's. I have a Galaxy too. Very frustrated. I've followed the suggestions listed but nothing is working...
Moderator edit: merged reply
09-20-2016 07:02
09-20-2016 07:02
Hi there @Jneil3817 and welcome aboard to our Community @333lisa.
@Jneil3817 I'm glad to hear you have received a replacement tracker and everything is good now.
@333lisa If the issue persist despite you have tried to restart your tracker; you can sync using a computer. It will depend which type of OS is running your Laptop but if you are using Windows, you can download the windows 10 app from the windows Store.
Turn the Bluetooth setting on. To verify, go to Start > Settings > Bluetooth. If your computer doesn't support Bluetooth, you need to plug the wireless sync dongle on any USB port of your computer. On the Fitbit app for Windows 10 dashboard, tap or click the Account tab. Tap or click your tracker to see the sync option.
If your computer is other version of Windows or you have a Mac computer. Download the Fitbit Connect Software from our site, which can be found free here: https://www.fitbit.com/setup
Once is installed on your computer do the following:
Hope this helps and keep me posted how it goes.
10-12-2016 14:00
10-12-2016 14:00
HI, I'm glad it worked for you. I did the same and nada! Sooo frustrating!
10-25-2016 10:56
10-25-2016 10:56
I'm in the middle of a challenge... will i lose todays data if i delete fitbit?!
10-26-2016 04:43
10-26-2016 04:43
Hi there @Myst49 and welcome aboard to our Fitbit Community.
@Myst49 I wonder what type of tracker do you have and where are you syncing, is it iOS, Android or other platform? usually I synced with an Android Device and I haven't experienced syncing issues, so if you are using the same platform or any different, you can find troubleshooting steps on the following post: Having trouble syncing? (here's how to fix this).
@Irvinemonteith you can also try with the post I mentioned before. If the steps are not working for the syncing issues you are having, note that you wont loose any of your information if you use the same account. Is very important to set your tracker using your existing account for this not to happen. Here you have the steps for iOS or Android, which is the most popular devices:
Hope this helps and let me know if the issue persists.
12-12-2016 16:44
12-12-2016 16:44
I have same problem, over and over. So frustrating . I think fitbit just trying to force me to upgrade from "flex"?
12-15-2016 11:27
12-15-2016 11:27
Hey @Flinchy, it's great to see you in this thread!
Sorry to read that you're having issues to sync your tracker. Since you already tried all the troubleshooting steps provided before I'd recommend to contact our Support Team so they can take a look in your account and provide you the best posible solution.
Please keep me posted with the outcome!
What's for breakfast?Check others recipes and share yours!
03-15-2017 10:08
03-15-2017 10:08
How do you delete Fitbit from your account? I just bought my Fitbit 2 days ago and it stopped syncing today. Extremely frustrated!!!
03-15-2017 10:13
03-15-2017 10:13
04-01-2017 07:17
04-01-2017 07:17
Hi.I have encountered the same problem. I uninstalled and then installed fitbit again and the sync worked. Two days later it did exactly the same thing, but still does not sync with the uninstall and re-install of fitbit. I have been reading the various comments so i thought to unpair and then pair the fitbit with my cell phone, but it stays on searching and does not go further. Has anyone got the solution for me.The blue tooth on the fitbit is on. Thanks
