09-12-2017
05:39
09:26
09-12-2017
05:39
09:26
If I click the + sign in the app and pick Track Exercise, I'm able to map a Walk, Run, or Hike. But no matter what I do, I can't get the app to offer Bike as an exercise option. I have Bike set up as an Exercise Option and GPS connected is "YES." So I'm stuck. Any suggestions?
09-12-2017 06:33
09-12-2017 06:33
Hey my friend @TyTheWriter, it's nice to see you here in the forums! Let's give this a shot, here we go:
First-time setup on iOS:
First-time set up for Android
Now, when you're ready for tracking your biking routine:
Syncing your tracker stores the workout in your exercise history. There you can find additional stats and see your route if you used connected GPS.
Let me know if there's something else I can assist you with. I'm always around!
09-20-2017 03:52
09-20-2017 03:52
Thanks, but this didn't answer my question...
09-20-2017 05:33
09-20-2017 05:33
@TyTheWriter The Charge 2 has two ways to track with GPS -- MobileRun and the Multisport (exercise) mode. You are starting your activity using MobileRun -- limited to walk, run and hike. You want the Multisport mode. Push the button on your tracker until you see the activity icon. I don't remember what the default first choice is. But I think it is either Run or Walk. Now tap the tracker until it gets to Bike. Push and hold the button to start/stop.
Here are two links to help you
Laurie | Maryland
09-21-2017 13:51
09-21-2017 13:51
@TyTheWriter, In your question, it states that Bike is setup as a multisport exercise on the Charge 2, this is the first step.
Then the Mobile Run in the Fitbit app is started and Bike is not an option. As @LZeeW explained, these are two completely different ways of recording an exercise, She and @MarreFitbit simply explaining how to use the Multisport mode to record a bike ride. This is what you setup the Cjarge 2 to do, wasn't it?
To answer your question about Mobile run, there is no option to record a bike ride, you will need to use the multisport mode on the tracker.
@LZeeW the default top exercise is run, but this can be easily changed in the Charge 2 settings.- exercises
07-24-2020 07:52
07-24-2020 07:52
I have the same issue, I have ionic, gps map only lets u select run, walk , hike
there is no adding bike ?
I always have to manually enter my rides ?
07-25-2020 13:13 - edited 11-04-2021 18:30
That is correct @Abby-girl, however we are on the Charge 2 support board and the Charge 2 does have the ability to track a bike ride.
Just by wearing the Charge 2, you can leave the phone home, the bike ride should be automatically detected.
Or use the bike mode for the Charge 2
But no distance or route.
11-04-2021 17:05
11-04-2021 17:05
How is this still not fixed?
11-04-2021 18:32
11-04-2021 18:32
What is it that needs fixed @mckillio?
11-20-2021 09:37
11-20-2021 09:37
I guess @mckillio means the fact that the tracking options still only give you hike - walk - run, and not outdoor cycle or mountain bike. I want the time elapsed and distance covered in miles. I’ve got a Fitbit 3 and an android phone. Even when the device detects the fact I’m on my bike automatically it still doesn’t tell me how far I’ve travelled.
Surely Fitbit aren’t going to continually ignore cyclists and can see the sense in adding the distance travelled too ?
11-21-2021 13:56
11-21-2021 13:56
If you are refferring to the fitbit app @DavRob you are correct, but this thread is in the hardware board and as mentioned above, your tracker is able to record the bike with GPS.
