12-09-2016
06:26
10:26
12-09-2016
06:26
10:26
How can I check my status in getting 250 steps during an hour?
12-11-2016 06:20
12-11-2016 06:20
@crmiles2 tthat is correct, the app will not tell you how many steps left in the hour to take.
On your Charge 2, next to the man is a number, this is the step count for the hour.
12-09-2016 07:13 - edited 12-09-2016 07:13
If you tap on the first screen towards the bottom it will scroll through the different screens at some point you will see the guy and then 144/250 or what ever steps you have done so far that hour.
Wendy | CA | Moto G6 Android
12-09-2016 09:50
12-09-2016 09:50
Thank you, WendyB. I wasn't aware of this and tried to keep track with the total steps.
12-09-2016 18:00
12-09-2016 18:00
Thank you for your reply, Wendy. I have not been able to find the man or the stats you mentioned in your reply. Is it on the bottom of the dash board page?
12-09-2016 19:31
12-09-2016 19:31
The little man is on the tracker on the same screen with your other stats, steps, distance, etc.
If it was on the app, you would first need to sync before it would be accurate.
12-10-2016 23:50
12-10-2016 23:50
12-11-2016 05:40
12-11-2016 05:40
@crmiles2 If you tap the screen on your Charge 2 it scrolls through stats. That is where you can see how many steps you currently have per hour. If you have met the goal already, it will show how many hours you have met the step goal.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
12-11-2016 06:20
12-11-2016 06:20
12-11-2016 07:56
12-11-2016 07:56
@crmiles2 Welcome to our Community! You can see the man on the tracker itself. On the first screen where you see the time you will need to tap several times (three in my case, I am using the fifth clock face).
You will see something like this:
Notice the guy with the arms up and the 91 next to him? That's the amount of steps I have done for this hour (don't judge me! lol).
Let me know how it goes!
12-11-2016 13:50
12-11-2016 13:50
Got it! Thank you very much for this info. I find it easier to use the app on my phone; I can see all my stats at a glance. It would be ever so nice if Fitbit would include the number of steps needed to reach 250 under the man - similar to the panels of how many calories you have remaining for the day or how much water you need to drink to reach you goal.
12-13-2016 06:29
12-13-2016 06:29
@crmiles2 Glad we all could help you and thank you for your idea. You can post these ideas in our Feature Suggestion board, first look if the idea hasn't been already posted and if you can't find it feel free to post you own explains what you would like to see or have implemented. The more votes an idea has the more likely the developers will try to implement it.
01-27-2017 17:40
01-27-2017 17:40
The post showing the little man illustrating the number of steps I've done in the hour is terrific to know. Now when I get my 10 minute notification I can calculate how many more steps I need for my hourly 250. When I first got my Charge 2 the 10 minute notification would do the calculation for me and tell me how many steps I needed to do. Now it just says something generic like want to take a stroll? Is there any hope that the Charge 2 will go back to showing the number of steps needed to get to 250 every 10 minute notification?
01-28-2017 08:07
01-28-2017 08:07
03-30-2017 15:35
03-30-2017 15:35
04-19-2017 11:06
04-19-2017 11:06
Hello~ I was wondering the same thing. I don't have the little man on my Charge 2 =( is there a setting I'm missing?
thank you~
04-19-2017 11:30
04-19-2017 11:30
Maybe you are missing something.
The display of these stats can be customized through the app. It's under the setting titled Customize Stats, and called Hourly Activity.
04-19-2017 11:48
04-19-2017 11:48
04-19-2017 13:26
04-19-2017 13:26
Yes that is what turns the man on. Try switching the order of tge stats then doing a sync
04-19-2017 13:39
04-19-2017 13:39
04-22-2017 07:11
04-22-2017 07:11
While your looking at the watch, tap the display. This will show your daily stats, one of which will have the man.
If your seeing the man and the word running, this means your pressing the button and switching menus. We want to tap the display to switch menu items.
