12-09-2016
06:26
10:26
12-09-2016
06:26
10:26
How can I check my status in getting 250 steps during an hour?
04-22-2017 07:20
04-22-2017 07:20
06-01-2017 08:31
06-01-2017 08:31
I hav the Alta HR and there isn't an hourly count next to my guy on the Hourly Activity page 😞
06-01-2017 08:35
06-01-2017 08:35
This isn't an option for Alta HR is it? 😞
06-01-2017 08:40
06-01-2017 08:40
This doesn't apply to the Alta HR does it? 😞
05-09-2018 07:00
05-09-2018 07:00
Hello, Can someone provide an image of the screen in which one see 144/250, 144 being the steps completed for that hour?
Thanks
07-18-2018 19:45
07-18-2018 19:45
Number of hours 250+ steps taken
No steps taken during 6pm hour
Hi justhavingfun,
Here are two pics. Tap on screen instead of using the button.
07-18-2018 21:16 - edited 06-03-2019 19:26
@MOIZME according to the Alta HR spec sheet you do have reminders to move.
06-03-2019 17:12
06-03-2019 17:12
I had Alta HR and it didn't tell me how many steps until I reached my 250 goal, until I have 10mins to get those remaining steps in
06-03-2019 19:29
06-03-2019 19:29
That is correct @MOIZME you only get a ten minute warning.
BTW it is usually faster to ask about the Alta HR on the Alta HR board. Many owners trackers only know about the model they own.
06-21-2019 09:43
06-21-2019 09:43
How do I get the little man to show me how many steps I need to take 10 minutes before the hour to reach my 250 steps?
06-21-2019 16:40
06-21-2019 16:40
Hello @MzChiz the little man will tell you how many steps have been taken until 250 steps, then he switches over to the hours that 250 where hit.
If you haven't gone 250 this hour then at 10 of there will be a notification with the needed steps.
06-22-2019 06:00
06-22-2019 06:00
The Fitbit I am referring to is my Charge 2. It isn't showing me the number of steps I am needing to take at 10 minutes to the hour. Also how do I get the dashboard for my Charge 2 to appear on my Fitbit app? It's only showing for my Alta and I am not wearing it right now.
06-22-2019 06:04
06-22-2019 06:04
Thank you for your help! My Charge 2 used to vibrate on my wrist at 10 minutes to the hour and it would show me how many steps I needed to take to reach my 250 step goal for the hour. It doesn't anymore.
06-22-2019 07:35
06-22-2019 07:35
Hello @MzChiz have you checked your reminders to move setting found under your Charge 2 settings?
As for the dashboard showing Charge 2, I'm not sure if I understand. Is your Charge 2 steps not showing up on your dashboard? The app and web dashboard is not about the tracker, but is about your activity. It is your dashboard, not the trackers dashboard.
Do you still have both trackers connected to your account? If so then you may simply pick up the tracker that you want to use.
06-22-2019 14:42
06-22-2019 14:42
Got it! It's working great. Thank you for getting back to me so quickly. You're awesome!!
