04-12-2020
09:19
10:02
04-12-2020
09:19
10:02
My husband gave me his Charge 2 when my Alta failed. The FitBit App on both phones were deleted and a FitBit App downloaded to my phone which is an iPhone running iOS 13.4 The Charge 2 was reset then we attempted to sync it to my phone but it would not. Please help, we have tried turning on/off/on the bluetooth and deleting all open Apps on the phone but cannot sync it to my account.
04-12-2020 09:28
04-12-2020 09:28
First on his phone, in bluetooth settings make sure the Charge 2 is not paired. If it is, then unpair it.
Then on your phone, log into the Fitbit app with the same account/email as you were using before, to keep all your historic data. Then, from 'Today' page, tap your profile pic at top left to get to the 'Account' page; then look down to 'Set up a Device' and follow the prompts. It will probably ask if this is a replacement for the Alta - yes.
04-12-2020 09:47
04-12-2020 09:47
Thanks for your prompt reply. I have tried 4 times to enter the number shown on the Charge 2 as part of the setup but each time i get a message that it was not the number on the display. Any thoughts on this problem?
04-12-2020 17:09 - edited 04-12-2020 17:11
Is their another Charge 2 around?
04-14-2020 00:37
04-14-2020 00:37
04-14-2020 08:28
04-14-2020 08:28
Care to share the solution?
04-14-2020 09:57
04-14-2020 09:57
I tried so many things its now difficult to remember exactly what happened on Monday but here goes:
I deleted the App from my husbands phone and deleted the App on my phone
I did a reset on the Charge 2 by connecting the charge cable, plugging it into a USB port on our MAC and holding the Charge 2 button for several seconds
I downloaded a new App and went through the setup procedure which included entering a 4 digit code
The Charge 2 then worked
