11-29-2016
18:17
10:26
11-29-2016
18:17
10:26
12-01-2016 06:20 - edited 12-01-2016 06:39
It's nice to see you around @Saunn!
Please try doing the following to turn it off:
If you have been doing this without luck, please try doing the following:
Keep me posted!
12-01-2016 06:22
12-01-2016 06:22
@Saunn Welcome to our Community! Try logging out from the app, restart your phone and log back in. Change the settings for the RTM and sync your tracker. See if this helps save the setting. You could also restart your tracker by doing the following:
1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
2. Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
3. Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display. Your Charge 2 will begin charging.
4. Press and hold the button on your tracker for four seconds. When you see the Fitbit logo and the tracker vibrates, this means the tracker has restarted.
5. Unplug your tracker from the charging cable.
Finally try changing the setting on a computer and sync your tracker from it (if you have one available with bluetooth or the USB syncing dongle) or try another mobile device to make these changes.
Let me know how it goes!
Best Answer12-03-2016 09:39
12-03-2016 09:39
Thanks for your suggestions!
I tried the solutions (resetting fitbit, logging in/out, and turning the slider "off" for the option) but nothing has worked. At the same time, I think my charger is faulty...sometimes it charges, sometimes it doesn't. Is this common?
Any other suggestions?
Best Answer12-03-2016 09:44
12-03-2016 09:44
Thanks for trying our recommendations @Saunn! My best recommendation would be to get in touch with Customer Support directly so they can do a deeper investigation with this and see where the issue may be coming from.
Have a great weekend!
