11-29-2020
11:51
16:17
11-29-2020
11:51
16:17
Think I need to reboot charge 4 but I can't enter settings to do that
12-01-2020 14:02
12-01-2020 14:02
My fitbit Charge 4 wont pair with my computer and I am unable to get the settings up as it is blanked out on the fitbit page on my computer. I cant change my clock face to something different and I was really stressed yesterday which I should not have been
18:00
16:32
12-01-2020
18:00
16:32
Hi everyone!
Thanks for your continued feedback and reports about this issue experienced with your Charge 4 devices. Just to confirm, may I know for how long you've had your trackers? I'm asking this as when a new tracker is recently set up in the Fitbit app, you'll need to wait until your tracker is offered to update to the latest 1.96.29 version which will allow you to navigate through your tracker's screens. If this is correct, please keep the Fitbit app running in the background to ensure your tracker will receive the update.
@raze14surya, I've moved your post so you can have more chances to receive help from the Community.
@jannyd60, let me explain that the Charge 4 was optimized to work with Android and Apple devices to ensure its connectivity and the performance of its features. This means that some features or updates won't work when using a Windows device. I'd recommend to use a compatible mobile device to complete your Charge 4 set up process.
Look forward to your comments.
Best Answer12-02-2020 03:09
12-02-2020 03:09
Hello,
I am not able to access my Fitbit Settings as well
Version 3.35 (20243544)
Firmware version 48.20001.94.13
12-02-2020 03:38
12-02-2020 03:38
12-02-2020 03:39
12-02-2020 03:39
have version 20001.94.13 We shouldn't have to wait for an update, it should be done automatically. Mine has been running in the background for almost 48 hours and still nothing
Best Answer12-02-2020 07:04 - edited 12-02-2020 07:05
It is downloaded automatically. The problem was that many people did not like to be dependent on a live Internet. Any Internet problems and the update crashed.
Fitbit gets yelled at for not making requested changes, then gets yelled at for when they give the user what they have asked for.
It is a learning curve trying to figure out what the user wants, and not what they are demanding that they want. Which turns out to be not what they wanted. Sometimes it simply is a case of asking for an option without thinking of the consequences.
Best Answer12-02-2020 07:53
12-02-2020 07:53
Hello,
I just downloaded the update and now able to access the settings and weather.
Thank you,
Anthony
12-02-2020 09:06
12-02-2020 09:06
Hello JuanFitbit, the tracker freezes when I tap the Settings tile. It freezes for a few seconds, the screen goes blank and restarts. I also did a few attempts to reboot it while plugged in but the issue wasn’t solved.
I'm using an iPhone 11.
Fitbit app version 3.35(1007)
firmware version 20001.94.13
Best Answer12-02-2020 09:07
12-02-2020 09:07
Hoping for this to be solved. Thanks!
Best Answer12-02-2020 13:09
12-02-2020 13:09
It looks like you just have to wait for the update like everyone is saying.
I had the same problem and could not get into setup either. I got my charge 4 on Monday and tried everything I could think of. Then I read in Comunity
that others were having the same problem and to wait for the Firmware to update. Today Wed the Fitbit app said the update was ready. I updated and
that took care of the problem. It looks like you have to wait for the update (48.20001.96.29) and it takes a few days
Best Answer12-02-2020 14:11
12-02-2020 14:11
Got the updated and all working great now so thanx for all your support
12-02-2020 17:03
12-02-2020 17:03
Best Answer12-02-2020 18:01 - edited 12-05-2020 09:24
I am not able to access my Fitbit Settings app, as well. Version: 3.35 (20243544). Firmware: 48.20001.94.13. How much time I should wait for this update? I bought the Charge 4 today.
I've just updated my device successfully and now I'm able to open the Settings apps. About 2 days to wait for the update. After that time, this update appear on the mobile app with a download icon and it took around 20 min to finalize the update. Thanks!
Best Answer12-02-2020 19:59
12-02-2020 19:59
I bought mine Monday and the update was ready this morning.
Best Answer12-03-2020 17:41
12-03-2020 17:41
Same version and same firmware version.
How do we get new firmware or update this brand new charge 4, or FIX it?
Best Answer12-03-2020 18:20
12-03-2020 18:20
Same thing!
Best Answer12-03-2020 18:27
12-03-2020 18:27
Update? How?? Owned it almost 2 days after Charge3 a long time. So disappointed. Don't know what to do.
Best Answer12-03-2020 18:31
12-03-2020 18:31
I'm live all the time. So, when will it update? I got it yesterday. On charger all night. Cannot access settings, and freezes. Tried reboot. Got smile, but all the same.
Best Answer12-03-2020 18:44
12-03-2020 18:44
When will new firmware be offered?!
Best Answer12-03-2020 18:56
12-03-2020 18:56
