01-12-2017
08:23
20:15
01-12-2017
08:23
20:15
Hi! I started experiencing issues with syncing my Charge HR about two days ago. It would not sync to my phone no matter what I did. So I Uninstaller the device, deleted the app, reinstalled the app. Now app would not even let me add a device... when I press and hold button in a Search mode, it starts tracking a workout.
I'd appreciate any help or advice.
Moderator edit: edited title for clarity
01-18-2017
15:34
07:02
01-18-2017
15:34
07:02
@slav9120 thanks for stopping by! Let's get your Charge HR paired to your account once again!
I'd suggest trying a restart by doing the following:
After that, attempt to pair your tracker once more and post me with the outcome! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
11-23-2017 09:26
11-23-2017 09:26
@MariamV, I'm also facing the exact same issue. I was not able to sync and hence deleted the device and now trying to re-add. But the Android App is not finding the tracker.
As per the steps you mentioned, how are we supposed to pair the tracker once it is unplugged from the charging cable. Fitbit app says to press the button for 3 seconds which starts the stopwatch !
14:51
07:02
12-05-2017
14:51
07:02
@bnyjohns thanks for joining us in this thread. Let's get your Charge HR added to your Fitbit account again. ![]()
Please follow these steps using your Android mobile device:
I really hope this helps. Keep me posted!
Best Answer06-01-2018 04:05
06-01-2018 04:05
Hi!
I was trying to sync my charge 2 this morning but it didn't quite sync. It showed the battery almost dead which is strange since I had charged it to the full last night. Also it showed the steps and the heart rate but didn't sync the sleep activity.
So I restarted the charge 2.
No difference.
Then I restarted my iPhone 7 plus
Same thing
Then I removed the charge 2 as a device on the app
Now it's not letting me add this device anymore.
Keeps saying com.fitbit.HTTP error 502
Best Answer01-13-2019 19:00
01-13-2019 19:00
Same thing is happening to me. The fitbit will not sync. Tried everything suggested in the forum. I get the code, type it in and then it says operation couldn't be completed (com.fitbit.HTTP error 403). It was working fine two days ago?? Help!
