Unable to check battery life while working out
How do I check the battery life of my charge 4 while I work out? I can’t seem to find it. Moreover, as I manually sync my device to the FitBit app, the battery life it displays from the app is inaccurate.
1 REPLY 1
Hi there, on C4, you tap the device to activate and then with your finger scroll the screen up.  You should see the battery %.
Good luck
