08-20-2022 11:42
08-20-2022 11:42
Whilst on holiday I didn’t charge my charge 3 before the battery died. Once recharged the charge 3 is unable to re-sync with my phone. I have tried all the suggestions to kick start a re-sync but I keep receiving the following message: Airlink request airlink error. I would really appreciate any help or suggestions as I haven’t been able to do a live chat with fitbit support, thank you
08-24-2022 12:28
08-24-2022 12:28
Hello again @PC1968
We can try to set up your Charge 3 as a new device to see if that helps your syncing issue. Before setting your tracker up as a new device please make sure your phone is update and look here to ensure your phone is also a compatible device: https://www.fitbit.com/global/us/technology/compatible-devices
Setting up your Charge 3 as a new device will not make you lose any data as your data is held on the Fitbit Servers. You will however lose all data that occurred after your last successful sync.
To set your Charge 3 up again as a new device please follow these steps closely:
😃 Maybe this will help your syncing issue. Please come back and let me know how it went.
08-20-2022 15:24
08-20-2022 15:24
Hello @PC1968
Can you try logging out of the Fitbit App, turn your Bluetooth then restart your phone. Once your phone restarts, turn your Bluetooth back on. Next log back into the Fitbit App and try syncing your Charge 3.
If that doesn’t help please let me know what steps you have already taken as you stated you have tried other suggestions to “kick start a re-sync”. It helps knowing what you have already tried.
08-24-2022 01:52
08-24-2022 01:52
Thanks so much for replying, but I have tried these steps already, several times, I’m beginning to think it might be a fault within the app as I was given a spare fitbit charge 3 from a friend who upgraded to an Apple Watch, and I cannot sync that one either 🤔 I’d really appreciate any other help you can give, thanks again 😄
08-24-2022 12:28
08-24-2022 12:28
Hello again @PC1968
11-07-2022 23:07
11-07-2022 23:07
Make sure the latest version of the Fitbit app is installed on your phone. The software on your mobile device is up to date. To check, tap Settings > General > Software Update. Make sure there are no other Bluetooth devices around as they might interfere with the syncing process.
Regards,
Will
