07-13-2020
09:08
08:37
07-13-2020
09:08
08:37
I have had my charge 3 since December 2018 and over the past couple of weeks the display has been getting fainter. To begin with the display disappeared from either side of the screen but now the middle section is so faint I can not even see the time. I know the Fitbit is working as is vibrates when I receive messages etc and it syncs and charges ok but is of little use if I can read it. I have reset the watch as per the guidelines and tried to change the brightness on the settings. Nothing has made any difference and it’s very frustrating. Please advise what my options are, thank you
10-01-2020 18:21
10-01-2020 18:21
Welcome to the Fitbit Community @TeresaWorcs.
I regret to hear that you are experiencing the same problem with your Fitbit Charge 3. Thank you for the information provided and for the time you spent while trying to resolve the issue.
This might be an issue with the software of your Charge 3. I just created a case with Customer Support. Please check your inbox on the next days. They will do their best to provide a high level of support.
Please let us know if you need further assistance.
07-15-2020 19:00 - edited 10-01-2020 18:17
Welcome to the Fitbit Community @Angelinaj.
I'm sorry to hear that your Fitbit Charge 3 display is not working properly. Thank you for the information provided and for trying to resolve the issue before contacting us.
Besides the regular restart you can also try a long restart by doing the following:
If you have any question, please let us know.
Best Answer07-16-2020 02:32
07-16-2020 02:32
07-16-2020 08:07
07-16-2020 08:07
I've been having the exact same problem. I've also tried all the reset options and the screen is still blank. It is vibrating and syncing with my phone but I can't see anything on the fitbit screen. Very frustrating. What options are available for those of us whose fitbits are not fixed by resetting them?
07-16-2020 12:02
07-16-2020 12:02
Did you get this sorted mine is the same .. tried all procedures nithings changed
07-16-2020 13:31
07-16-2020 13:31
07-17-2020 00:37
07-17-2020 00:37
I’ve had no further response yet but that didn’t work for me
07-17-2020 02:15
07-17-2020 02:15
hi mine did this for about a month. Got more and more faint so i couldnt read it then eventually i got the white lines of death! its on its way out i am afraid.
07-17-2020 06:23
07-17-2020 06:23
I am having the same issue with my Charge 3. I know it is working normally ... just no screen! Help!! I have tried all the resets and it makes no difference.
07-17-2020 12:51
07-17-2020 12:51
07-23-2020 19:07
07-23-2020 19:07
Hello everybody, thank you for visiting the Fitbit Community.
@Angelinaj, to evaluate this situation, I created a case with Customer Support. Please check your inbox on the next days. They will let you know how to proceed as soon as possible. Thank you for your patience in the meantime.
@Linsbuc @Coxpipin @Huntee01 @SunsetRunner, please try to change the clock face by following these steps. If this doesn't work, please verify if your device vibrates when you customer press the button.
Please let us know if you have any question.
07-24-2020 07:31
07-24-2020 07:31
As I mentioned before, I've already tried all of these reset options and tips, including changing the clock face in the app. Nothing has worked to make my screen come back on. What options are available for those of us who have tried everything and are still unable to have a working screen?
07-29-2020 18:04
07-29-2020 18:04
Thanks for your response @Linsbuc.
For further investigation, I sent this information to Customer Support. They will get in touch with you as soon as possible. Please keep an eye on your inbox.
09-29-2020 15:54
09-29-2020 15:54
I've got the same problem - since the last software update a few weeks ago it has got worse. I have it set on Auto or on Normal in the day time but can only see the screen properly in the shade, outside it's just too faint. Sometimes it lights up properly if I press the left side button or tap it a few times, but it is only for a few seconds then goes dim again. The whole text on the display looks patchy and faded instead of clear and bright. I can just about read the time but not the steps or heart rate. This seems to be a common problem recently with this model. Is it a software or hardware problem? Thanks.
10-01-2020 18:21
10-01-2020 18:21
10-02-2020 00:22
10-02-2020 00:22
Best Answer10-09-2020 23:47
10-09-2020 23:47
My Fitbit Charge 3 screen goes from bright to dim. I can't read the screen. I have tried all the solutions that are given but the screen of its own accord will turn dim. Very very frustrating.
10-13-2020 13:56
10-13-2020 13:56
Welcome to the Fitbit Community @sp3.
I'm sorry to hear that your Fitbit Charge 3 screen goes from bright to dim. Thanks for trying the solutions provided above before contacting us and thank you for the information provided.
To evaluate this situation, I created a case with Customer Support. Please check your inbox on the next days. They will let you know how to proceed.
Best Answer10-13-2020 13:59
10-13-2020 13:59
10-13-2020 14:29
10-13-2020 14:29
I think there has been some recent changes to the Charge 3 settings that weren’t always there. For instance, mine stopped giving me notifications. Just today I figured out many things are now listed in the “Settings” screen. This can be found by swiping all the way over to the left. Once there, you can adjust Brightness, which might be set to dim. It should be set to Auto. If you tap this setting, it will cycle through all the options. My problem was that I had unknowingly set my Do Not Disturb to On. That’s why I wasn’t receiving any notifications. Once again, you can tap this to cycle through the options. Use the left big button to return back to home after you have corrected your settings. I also rebooted my device by tapping About (bottom of the settings screen) and then scrolling to the bottom again until you get to Reboot Device. After tapping that and the device successfully reboots, you will see a happy face appear on the screen.
I hope this helps. Like I said, I never noticed these settings when I got my device in June but they are now there and apparently wrecking havoc with users. Good luck!
