06-08-2020
19:32
16:17
06-08-2020
19:32
16:17
I've tried the reset by charge 4 with the steps online without any success. Any suggestions.
06-08-2020 19:40
06-08-2020 19:40
Did you follow these restart instructions?
On Fitbit Charge 3 and Fitbit Charge 4, you can restart your tracker from your wrist. Open the Settings app
and tap About > Reboot Device.
If your Charge series tracker is unresponsive: .
Your tracker should now work normally. If your tracker still doesn't work after a restart, contact Customer Support.
If so, what do you mean by "without any success"? Do you think that it did not do a restart? Or did it not solve whatever problem you were dealing with?
09-07-2020 14:38
09-07-2020 14:38
My charge 4 is unresponsive. I'm stuck with the Fitbit logo.
Smiley face does not appear after keeping the button pressed 8 seconds. And yes, the device is on the charger.
Any suggestions?
01-23-2021 07:49
01-23-2021 07:49
Mine just keeps showing me the charging status and the time. It refuses to restart no matter how long I hold the button. It's been like this since I got it, but have been able to get it connected anyway in the past. Hasn't synced for 3 days now. I'm beginning to think it's time to check what's left on the warranty.
08-18-2022 17:23
08-18-2022 17:23
I know this is an old thread… But I will offer this advice in case it helps anyone else. I had this issue as well (no restart despite holding the button for a while during charging). I found that the issue was that the pressure of holding the button slightly dislodged the charger for a brief moment - so it never registered the 8 second hold. I think cleaning the charger or the fitbit might help, but what worked regardless was to press the fitbit into the charger while also holding the side button to prevent it from sliding around and losing contact with the pins.
08-21-2022 20:02
08-21-2022 20:02
This solved my problem! Thank you!
