Unable to see all Notifications I get on my Charge 4
When I get a notification on my Fitbit, it will buzz and come through. However if I get multiple notifications, when I try to scroll through them, the list only shows the most recent notification and I can’t view any others. I’ve checked my Bluetooth connection and there’s no issue with that, and I do get the notification just then can’t view it if I’m send another.
1 REPLY 1
It's good to see you participating in the community @Manchester123.
Thank you for sharing the details regarding the inconvenience with your Charge 4.
Before considering other options, make sure to follow all the steps listed here to resolve problems with notifications. This has been useful for other users experiencing the same problem.
Make sure that you have the latest version of the Fitbit app installed and to check all the compatibility requirements here.
