12-13-2020 07:17
12-13-2020 07:17
My change 3 was working and sync well with iPhone 11 max pro for more than 4 months. After that it’s belt start cutting from edge and stoped use for more then 3 months and apply for new belt as it’s under warranty. Due to some issue belt didn’t reach my place and finally I purchased new belt from Amazon.
now trying Sync with same iPhone but no luck. Tried all possible options like data detain hard reset, reinstall app on phone, delete data from charge 3. Anyway this absolutely lost of precious time and money. After paying premium prices.
12-13-2020 17:13
12-13-2020 17:13
Hi @SunsetRunner749 thank you very much for your information and efforts.
Please make sure no other bluetooth device is connected to the laptop or nearby. (Headphones, keyboards, etc.)
On the phone, check that the battery saving mode as well as do not disturb (silence ) mode are off.
Please follow these steps, some you have already done, but the order is important:
Please let me know how it goes
Best Answer12-13-2020 18:31
12-13-2020 18:31
Best Answer12-14-2020 15:16
12-14-2020 15:16
Hi @SunsetRunner749 , thank you for your reply and efforts.
Please on the Fitbit app, go to your profile picture>Help. As a title you'll see the version of the Fitbit app. Could you please check that you have the current version 3.36 installed?
If not please update the app and retry the previos steps.
Let me know how it goes
Best Answer12-14-2020 21:34
12-14-2020 21:34
Best Answer12-15-2020 17:51
12-15-2020 17:51
Hi @SunsetRunner749 , thank you for information. Support informed me that you contacted them. They are reviewing your case and you'll receive a reply via email very soon.
Let me know how it goes.
