05-20-2020
17:52
09:40
05-20-2020
17:52
09:40
Since yesterday, my Ipad has not been syncing with my Charge 2. I updated the software on the I-pad, turned the I-pad off and on, and turned Bluetooth off and on, but none of these worked. My I-pad indicates that my Fitbit is not connected to the Bluetooth. Any solutions?
05-20-2020 18:41
05-20-2020 18:41
Same. Did you find a solution?
Best Answer05-20-2020 19:37
05-20-2020 19:37
Not yet.
Best Answer05-22-2020 05:34
05-22-2020 05:34
I just called Customer Support. The solution was very simple. Went to Blue Tooth on Settings and found my device listed. It was shown as not connected. Clicked on small blue icon and then on statement to forget device. Then went to Fitbit app on my I-pad. It started syncing immediately, and I was able to get all the data since when my Fitbit stopped syncing.
Best Answer05-26-2020 03:58
05-26-2020 03:58
