03-17-2017
05:49
09:49
03-17-2017
05:49
09:49
There is not any kind of problem measuring the distance and get the map in Run mode.
I try several time in several mode to get the distance for Biking mode: first pairing my Iphone with the wrist, select the Bike mode and start; start the Bike mode in the wrist and than pairing the phone.
What I am doing wrong ?
03-11-2017 01:31
03-11-2017 01:31
When I start 'bike' on my Charge 2, the Charge registerd the tome, but no distance ..
It isn't connected with my smartphone.
I only wear the Charge 2;
On my PC I use, an older version of 'Fitbit Connect , with the doccle'. When I use my Sony X Peria, and I syncronished with the App, I can't see anything on my PC.
Can anyone help me?
Best Answer03-11-2017 08:24
03-11-2017 08:24
The Charge 2 does not contain a GPS chip so there is no way it can know the distance by itself. It can connect with a supported phone and use the chip in the phone though.
03-11-2017 08:36
03-11-2017 08:36
@kristen to add to @SunsetRunner' post, make sure the tracker has a phone icon without a line through it and you have the phone with you.
You need the GPS to get the distance while Biking.
03-11-2017 15:39
03-11-2017 15:39
Thw for the answer.
Can the Charge 2 registred a distance whem I'm biking without a GPS of phone near by?
Best Answer03-11-2017 15:48
03-11-2017 15:48
No, @Kristien, without Connected GPS the tracker will have no way to measure distance on the bike.
03-17-2017 02:56
03-17-2017 02:56
For the past few days, my Charge2 has been underrecording distance on bike mode. For walk mode it seems fine.
I know the distance as it is a ride/walk I do regularly and am recording the activity on both my fitbit and via Strava (I have not connected the two). Everything else seems to recorded correctly. The map of my journey is correct, the time spent travelling is correct, the heart rate recording is continuous.
What is the problem? in some ways, it does not matter but if I want to use the date to evaluate performance via average speed this is no use.
Help
Charlotte
03-17-2017 07:54
03-17-2017 07:54
@deocamdata, there appears to be a problem with the Bike exercise mode and Connected GPS. I am experiencing the same problem with my Charge 2 and my Android phone. The last bike ride recorded time and calories only, with no distance. This problem has been reported to Fitbit, so hopefully it will be fixed in the near future.
03-17-2017 08:43
03-17-2017 08:43
Thank you.
It is really annoying.
Let's hope that they will fix it soon
03-20-2017 06:11
03-20-2017 06:11
@deocamdata @CB55 It's nice to have you on board! As @USAF-Larry said this is a bug being investigated. Usually it happens when you pause your biking activity as this is a common denominator but if you don't pause it could you please provide the phone, os version it is running and the app version to better investigate this issue. Also when using the connected GPS function always allow enough time for the phone to find the GPS signal and connect with your tracker. You could also try turning your bluetooth off, wait 1 minute then turn it on and after this restart your tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
This to improve the communication between both devices.
Let me know how it goes!
Best Answer03-20-2017 08:03
03-20-2017 08:03
I will try this
I hope it will works because I hate Strava
I use Iphone 6 S plus
Best Answer03-21-2017 04:05
03-21-2017 04:05
I am using a Samsung Galaxy S6 phone. And despite resetting everything, I still had the same problem this morning.
In terms of pausing, I am riding to work which means that I have to stop at lights, in traffic, for pedestrians etc... I do not pause my Charge2 at each stop, irrespective of how long the wait has to be.
Best Answer03-21-2017 04:37
03-21-2017 04:37
@CC45Angel the only time a wait would matter if your letting the tracker auto detect the bike ride.
If you start and stop it from the tracker you are telling it how long to stay in bike mode.
Do you see a map after you sync?
Best Answer03-21-2017 07:26
03-21-2017 07:26
@AlvaroFitbit .... unfortunately your advice doesn't work ...
Everything it's ok with the gps in "run" mode ... nothing in "bike" mode
03-21-2017 07:32
03-21-2017 07:32
Best Answer03-24-2017 09:33
03-24-2017 09:33
Best Answer03-24-2017 10:42
03-24-2017 10:42
Do you see a map after the bike ride? This would be a way to tell if the GPS was working. For a bike ride to show distance, the user must use the multisport mode with connected GPS and a map will be produced.
You will also see a small phone icon on the tracker saying that it is connected to the phones GPS.
GPS may also have been turned off under the Charge 2 - Exercise - Bike settings.
Best Answer04-07-2017 10:48
04-07-2017 10:48
I have also problems with the map-distance. When i Bike to my work in the morning everything is allright. But when i go home and check my fitbit at home. The distance is not correct. Everything else is good, the time and the heartbeat is correct. But i allready read now that the problem is known. So i hope that is soon solved.
04-11-2017 06:10
04-11-2017 06:10
There still seems to be no resolution to this problem. My Charge 2 used to record distance correctly. This is not helpful as it gives me incorrect speed information.
Best Answer05-22-2017 10:10
05-22-2017 10:10
Is there any up date on Fitbit sorting the bike distance tracking bug?
