03-17-2017
05:49
09:49
03-17-2017
05:49
09:49
There is not any kind of problem measuring the distance and get the map in Run mode.
I try several time in several mode to get the distance for Biking mode: first pairing my Iphone with the wrist, select the Bike mode and start; start the Bike mode in the wrist and than pairing the phone.
What I am doing wrong ?
03-29-2018 10:04
03-29-2018 10:04
Best Answer03-30-2018 11:21
03-30-2018 11:21
Interesting. I had to recharge Wednesday evening 3/28 (Today is 3/30). While at it, I id a couple power cycles. Results on yesterday's rides:
To Work:
Phone: 5.14 mi
Fitbit: 4.71 mi
Error: 8.4%
From Work:
Phone: 4.84 mi
Fitbit: 4.45 mi
Error: 8.1%
Still not great, but better than the 30% error I got on Wednesday.
Best Answer03-31-2018 16:58
03-31-2018 16:58
Look at page 18 of the user Manual it shows exactly what the different options mean on the phone icon.
You can also just go to the online version under the help link found below.
Best Answer04-04-2018 04:02
04-04-2018 04:02
Best Answer04-04-2018 04:57
04-04-2018 04:57
@kbams I had to search out your other post to see if I could figure out the problem.
Do you get a record with the map of your ride? Do you manually start the bike recording mode, not letting the auto detect function decide?
To go back to your past post, calories are calculated using the heart rate and time .Distance is not a part of the calculation, especially since Fitbit doesn't know what gear the bike is in.
Best Answer04-04-2018 16:35
04-04-2018 16:35
HI, thanks for all of the replies. I managed to get the Charge 2 to track the ride, up to a point. I had to make sure the phone app was actually running before I started, despite having location settings on the phone set for Fitbit to use them "always". However, the tracking is wildly inaccurate. At one point it has me travelling on the opposite side of a river that is about 500m wide! It also leaves out anything after I pause and resume tracking. Fortunately, my Garmin bike computer does an excellent job. It is apparent that the Charge 2 is a very imperfect device and really only useful for tracking steps.
18:31
08:16
HeydyF
04-22-2018
18:31
08:16
HeydyF
GPS appears to track location and doesn't seem able to convert into accurate mileage. In this situation for a bike ride.
Garmin and Strava recorded 36.5 miles, Charge 2 10.68 miles. Time for all three the same.
Best Answer04-23-2018 08:15
04-23-2018 08:15
Hello @KiwiJohn51, it is great to see new members around!
Could you please post screenshots of the mileage tracked by your Garmin, Strava and Charge 2 so I can take a look? In the meantime, I'd like you to review the troubleshooting in this post, to improve the accuracy of the GPS signal between your Android device and your Charge 2.
Let me know how it goes!
Best Answer04-28-2018 19:28
04-28-2018 19:28
Best Answer04-30-2018 07:33
04-30-2018 07:33
Hey @KiwiJohn51, thanks for the update! That is correct my friend, your Charge 2 and your phone needs to be as close to each other as possible and of course the Bluetooth and the GPS location, both have to be ON while you are biking so it can track your whole distance and give you a map of your route.
If you have further questions or comments, keep me posted!
Best Answer05-09-2018 01:34
05-09-2018 01:34
Hi,
Can anyone from fitbit (support) answer why GPS data is wrongly calculated? My Surge has never been able to calculate my distance on the bicycle! I constantly get 3-4 km when it is really 9 km. The track is correct and shows on the map but the distance is sooo **ahem** wrong. I know, I am using the "running" profie since the spinning profile doesn't collect GPS data. But the calculation of distance includes errors for running as well, albeit smaller.
I have read other posts and I can see suggestions on changing stride length. Well that is just ridiculus!
GPS data is the best way to calculate the actual distance. The distance and time is also the ultimate tool to calculate your performance. Asking the olympic commitee to select a winner for 3000 m track run based on estimated stride length is just absurd!
Some of my training partners also have fitbit and the issue is annoying. When they tell you that your Fitbit watch is unreliable as a chinese car from the 70's, then you get really sad. It is getting embarassing to wear this piece on my arm.
Get real and get serious! When are you going to fix it?
Ready to join the dark side!
05-15-2018 08:02
05-15-2018 08:02
Hi Alvaro. I am experiencing the same issue and it has been like this for some months now. When I was in South Africa the bike mode worked perfectly, recorded all my exercise metrics. Now I am in the UK and my steps, run, gym, every other setting works except my bike mode. The timer works but none of my other stats are retrieved. I have followed the below but still it does not work.
I bought the Charge 2+ in around September last year.
Best Answer05-26-2018 10:08
05-26-2018 10:08
Agreed. New fitbit charge 2. SO disappointed. Wishe id read these forums.
No sleep mode now this.
NOT PLEASED WITH MY PURCHASE AT ALL
05-28-2018 16:36
05-28-2018 16:36
My Charge2 did not register distance or time while I was biking. I had phone with and bluetooth was turned on.
Best Answer06-05-2018 09:56
06-05-2018 09:56
My phone was tracking my Charge 2 mileage fairly accurately until this last week. My ride is a back and forth ride. It seems that it is now calculating my distance only once. Instead of 24 miles, it now says I am going 9.1 miles. I am ready to lengthen my ride, but I would like an accurate reflection of the actual distance I travel in each direction, not just one direction.
Best Answer06-09-2018 19:44
06-09-2018 19:44
Hello Fitbit community. Have a problem which I was hoping someone can help with!
I have a Charge 2 and a Moto X4. I went biking today and thought that Fitbit will auto recognize the exercise. It did auto recognize; however, I don't see any GPS data - no distance, no maps, no splits. Is this expected behavior? Should I have rather started tracking the bike ride manually through the tracker?
Please suggest. Thank you.
Best Answer06-11-2018 08:39
06-11-2018 08:39
Hello @mt13, welcome aboard! Let me explain to you that there are 2 ways to track your exercises with the Charge 2 . One of them, the SmartTrack, is the one that auto recognize the exercises that you have selected through the Fitbit app if they meet the minimum time that you also have to set. Within this feature, you can find outdoor bike, however, it won't give you GPS map or distance. For further information about this, take a look at this help article.
In regards of the other option to manually track your activity, you can select bike on the Charge 2 itself (you have to set this exercise as well on the Fitbit app) and if you want to get GPS map and distance, you have activate the connected GPS between your phone and your Charge 2 and of course take your phone with you, but also, you mentioned that you have the Moto X4 which hasn't been added to our compatible devices list, so I can't guarantee that it'll work. Anyway, I urge you to take a look at this other help article to get further information about this option and how to use it.
Keep me posted if you have further questions!
06-11-2018 19:13
06-11-2018 19:13
Thank you @HeydyF, for the details you provided. I understand now. I will make sure to track the workout manually the next time I am out biking.
Best Regards
MT
Best Answer06-12-2018 05:27
06-20-2018 06:10
06-20-2018 06:10
I have a same problem but with my running. I’ve tried both ways to record it. Fitbit says it’s a glitch what they working on but I think it’s just not good enough. I use Strava to record my distance and show map using its gps. 😤
